Honda Fit Honda Fit (Jazz)
Not as low as DougiePants but close....
Old Jul 23, 2006 | 07:10 PM
ChrisG's Avatar
Default Not as low as DougiePants but close....
The wheels are 15x7.5 with a +27 offset, for those that it couldnt be done!!!!!
Old Jul 23, 2006 | 07:18 PM
jo3blo3's Avatar
Default Re: Not as low as DougiePants but close.... (ChrisG)
Sweeeeeeet Ride!
dmxsoulja3's Avatar
what is it lowered with? Looks good and beefy
Old Jul 23, 2006 | 07:29 PM
ChrisG's Avatar
Default Re: Not as low as DougiePants but close.... (dmxsoulja3)
Vogtland springs
Old Jul 23, 2006 | 08:49 PM
dmxsoulja3's Avatar
Man and thats with a smaller size tire than stock, probably rub like crazy on the stock sport alloy's..
Old Jul 23, 2006 | 09:17 PM
Dacalac's Avatar
did u have to roll the fenders??
Old Jul 24, 2006 | 01:00 AM
EmbersAndEnders's Avatar
Looks pretty sick. Like said above how's the rub?
P.S. The NO WAKE picture made me laugh. Don't know why but meh.
Old Jul 24, 2006 | 05:31 AM
nightshift's Avatar
Default Re: Not as low as DougiePants but close.... (EmbersAndEnders)
How much did you lower the front and back? Did you get stiff springs or shocks so it won't rub? I'm thinking of getting those rims or the black ssr's.
Old Jul 24, 2006 | 06:36 AM
ChrisG's Avatar
Default Re: Not as low as DougiePants but close.... (nightshift)
The springs I believe lower the car 1.6" up front and 1.4" in the rear but after settling I believe it will be lower than that! As for the shocks they are stock for now, I have not been able to track down an aftermarket set of shocks/struts. But if Koni makes a set IM GAME, along with if Ground Control makes a set of coilovers!
Nightshift - Do you have your Fit yet? And where are you at in Va Beach, and do you post on DragVA?
Old Jul 24, 2006 | 11:21 AM
92acclude's Avatar
They look perfect.
Old Jul 24, 2006 | 02:21 PM
spoonek4's Avatar
Wow I was thinking K1 15x7 in about +35mm offset or so and u have 15x7.5 +27!!! Look great but I think u need some wider tires for those 15x7.5 bad boys.
Old Jul 25, 2006 | 09:14 AM
claymore's Avatar
Default Re: Not as low as DougiePants but close.... (spoonek4)
Are your tires going to last longer than dougies??
Old Jul 25, 2006 | 11:22 AM
jetydosa's Avatar
25 Year Member
Default Re: Not as low as DougiePants but close.... (claymore)
Love the K1s!!! Looks awesome. How is the ride with the springs?
Old Jul 25, 2006 | 12:24 PM
SuzukaBlueAP2's Avatar
Default Re: Not as low as DougiePants but close.... (jetydosa)
K1s
HIDs
Vivid blue
Old Jul 25, 2006 | 12:56 PM
nightshift's Avatar
Default Re: Not as low as DougiePants but close.... (SuzukaBlueAP2)
Would you get mad if I get the exact same color sport fit with the exact same rims from the tire rack? How do you drive with that thing without rubbing the fenders? And how do you change the offset?
Old Jul 25, 2006 | 01:01 PM
fitfreak3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightshift &raquo;</TD></TR><TR><TD CLASS="quote">Would you get mad if I get the exact same color sport fit with the exact same rims from the tire rack? How do you drive with that thing without rubbing the fenders? And how do you change the offset?</TD></TR></TABLE>
Would you get mad if I called you RETARTED?
Old Jul 25, 2006 | 01:04 PM
jo3blo3's Avatar
Default Re: Not as low as DougiePants but close.... (fitfreak3)
Sorry... but it's spelt RETARDED and I wouldn't get mad at you for calling him that.
Old Jul 25, 2006 | 01:09 PM
fitfreak3's Avatar
Default Re: Not as low as DougiePants but close.... (jo3blo3)
Retarted means retarded in a good way. J/K
Old Jul 25, 2006 | 02:16 PM
FBP_Si's Avatar
Old Jul 25, 2006 | 05:00 PM
EG8R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmxsoulja3 &raquo;</TD></TR><TR><TD CLASS="quote">Man and thats with a smaller size tire than stock, probably rub like crazy on the stock sport alloy's..</TD></TR></TABLE>
How is it smaller? Going from a 195/55 to a 205/50 = bigger tire. Sidewall stays nearly the same but the width is 10mm wider and I think OEM tires roll inwards more at the tread than what these tires do...
Old Jul 25, 2006 | 07:12 PM
primoEF's Avatar
wow the K1s look really good on the blue fit very nice
Old Jul 25, 2006 | 08:25 PM
efficiencyJunkie's Avatar
Default Re: Not as low as DougiePants but close.... (primoEF)
Looks hot, and Functional!
too bad they are gonna stop making the k1's.
What is your camber setup? (btw, any fender rolling? Didnt see your respond to that.)
Old Jul 26, 2006 | 02:41 AM
ChrisG's Avatar
Default Re: Not as low as DougiePants but close.... (carbnjunkie)
I didnt roll any of the fenders, I just bent up some of the tabs in the fender so they wouldnt puncture the tires. Im not aware of any camber kits being out yet. So the camber that you see is just from the spring install!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbnjunkie &raquo;</TD></TR><TR><TD CLASS="quote">Looks hot, and Functional!
Old Jul 26, 2006 | 07:10 AM
Moto-hashiriya's Avatar
Springs only with S tires LOL
Old Jul 26, 2006 | 03:51 PM
94civicCx's Avatar
look great!
