Oil ?
Old Jul 23, 2006 | 05:35 PM
spoonracer84eg's Avatar
Default Oil ?
I was changing my oil on my b16 and I accidentaly kicked over my 4th qt. The oil level is sitting right below the fill line. Will I be good to go to work tomorrow then run to the delearship to get another qt of oil at that oil level??
Old Jul 23, 2006 | 05:46 PM
knockout's Avatar
Default Re: Oil ? (spoonracer84eg)
if its right below it and as long as you can see oil on the dipstick you'll be fine. but I wouldnt recommend running it for a long time or revving it too high (depending on how low the level is). so if youre just gonna go get some tomorrow, youre good.
Old Jul 23, 2006 | 05:49 PM
I just dont want to mix other oil with the honda oil. Ill just drive normal and get to the dealership after work. Thanks.
Old Jul 23, 2006 | 05:53 PM
knockout's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonracer84eg &raquo;</TD></TR><TR><TD CLASS="quote">I just dont want to mix other oil with the honda oil. Ill just drive normal and get to the dealership after work. Thanks.</TD></TR></TABLE>
no prob. but for future reference, oil is oil is oil is oil. no need to worry about mixing oils (as long as they are somewhat similar in viscocity)
unless youre running high horsepower or you have some crazy setup it'll be fine. even so, you'd probably be fine anyways.
Old Jul 23, 2006 | 06:36 PM
Paprika's Avatar
Yeah man I mix Valvoline with that walmart stuff (umm.. Supertech :-p) with Exxon with Mobil 1.
Heck yahaaa!
FitsMe
Honda Fit
Apr 16, 2012 05:05 AM
highwhey
Nov 11, 2010 05:53 AM
00pr3lude
Feb 13, 2008 09:04 PM
"Ridge"Racer
Honda Civic (2006 - 2015)
Aug 8, 2007 05:22 PM
VtecDA9
Nov 21, 2004 03:12 PM
