91 Accord highbeam bulb replacement
It's right behind the battery and is held in with a plastic collar. sometimes it's hard to get the collar to twist loose, silicone spray might help. unplug the wires first then unscrew the collar about 1/4 turn. The bulb is seated on an 'O" ring, so you might have to wiggle it out. When you get the new bulb don't touch the glass, the oils in your hand can cause spots on the bulb after it gets hot.
r0ckingrrl
Nov 1, 2004 03:10 PM
. Any one out there know how to get to it?
