knock sensor on 94 h22a swap??
Old Jul 23, 2006 | 04:13 PM
prelude72569858's Avatar
Default knock sensor on 94 h22a swap??
i have a 94 H22a w/94usdm ecu, what needs to be done about the knock sensor?? the h22a dosnt have one
Old Jul 23, 2006 | 04:47 PM
98vtec's Avatar
moderator emeritus
Default Re: knock sensor on 94 h22a swap?? (prelude72569858)
yes it does.
Old Jul 23, 2006 | 08:27 PM
oranginal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">yes it does.</TD></TR></TABLE>
x2
did u mean that it didn't come with one, because most of the knock sensors from honda/acura are interchangable as long as they are the same either obdI or obdII
but if u want u could always chip the ecu to make it bypass the knock sensor. but that is not safe or recommended and will probably result in ur engine blowing up.
if u mean u cannot find it then look again at the back of the block above the oil filter for either a black or green sensor(not sure of color) since it is obdI it should have 1 pin comming out of it for the connector.
hope this helps u out prelude 72569858
Old Jul 24, 2006 | 01:32 AM
there isnt a sensor there (94 jdm H22A) looks like there is a plug of some sort on the block that you can take out with a 3/8 ratchet (maybe1/2) .........think i have to add it?? someone has to know
Old Jul 24, 2006 | 02:35 AM
thahuhstunna's Avatar
Default Re: (prelude72569858)
check your other thread genius... now that i know which ecu you're using, yes you're going to need it if you want your **** to run right... so go get one and quite posting the same crap multiple times in the same damn forum
Old Jul 24, 2006 | 06:24 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude72569858 &raquo;</TD></TR><TR><TD CLASS="quote">there isnt a sensor there (94 jdm H22A) looks like there is a plug of some sort on the block that you can take out with a 3/8 ratchet (maybe1/2) .........think i have to add it?? someone has to know</TD></TR></TABLE>
Sounds like someone removed the sensor and plug it with an insert.
Old Jul 24, 2006 | 01:57 PM
so i need to buy one and put it in place of the plug?? (using P13 ECU) would not having a knock sensor cause the ecu to cut the fuel (negitve pulse) completly??
Old Jul 24, 2006 | 02:27 PM
why would somone remove the knock, i did buy the swap from a private owner but the motor was still strapped the the pallet looking like it came from striaght from japan
Old Jul 24, 2006 | 06:26 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude72569858 &raquo;</TD></TR><TR><TD CLASS="quote">why would somone remove the knock, i did buy the swap from a private owner but the motor was still strapped the the pallet looking like it came from striaght from japan</TD></TR></TABLE>
Probably running a chipped P28. P28's don't need a KS.
Old Jul 24, 2006 | 06:28 PM
thought about that but why go throught the trouble of removing then finding a cap, when you could just let it be????
98vtec's Avatar
moderator emeritus
maybe he needed the money and sold it.....
prelude72569858
Jul 24, 2006 05:32 PM
rival12
Jan 25, 2005 12:18 PM
Subwarrior
Jan 6, 2005 08:02 PM
