WHat camber kit for my needs?
Old Jul 23, 2006 | 03:11 PM
turbotime's Avatar
Default WHat camber kit for my needs?
Hey im tired of my tires being worn weird and my steering being slightly off due to bad camber. I want to get a camber kit but there are so many different ones I dont know which is best for me.
I want camber kits for front and rear but i dont want a kit that is going to be loud or rattle. Will the washer trick work fine for the rear camber? Is it rattly?
What about for the front? I have seen lots of different kits some use UCA's and others use the tie rods? Which is best for a quiet ride and daily driving?
Old Jul 23, 2006 | 10:58 PM
turbotime's Avatar
Old Jul 23, 2006 | 11:19 PM
d16yR's Avatar
Default Re: WHat camber kit for my needs? (turbotime)
the washer trick for the rear is fine just have to get longer bolts, but if you are in to auto-X or road racing it be best to get adjustable camber, i've used the washer trick but when i got into auto-x I upped to the skunk2 rear camber kit and also i'm using skunk2 front camber kit works great
Old Jul 24, 2006 | 12:30 AM
FalkenSiR's Avatar
I just can't believe that an 03 member doesn't know that camber is not the factor that wears out tires. And since when camber kits are "loud" or "rattley"?
An 03 member should know better and search before asking something he doesn't know, specially a camber question
Old Jul 24, 2006 | 06:30 AM
turbotime's Avatar
Default Re: WHat camber kit for my needs? (fast95eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 &raquo;</TD></TR><TR><TD CLASS="quote">An 03 member should know better and search before asking something he doesn't know, specially a camber question </TD></TR></TABLE>
whatever man. just answer the question and stop being a smartass.
Ive "heard" some front kits are noisy, i was wdonering which if any these kits were so that i DONT buy them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 &raquo;</TD></TR><TR><TD CLASS="quote">I just can't believe that an 03 member doesn't know that camber is not the factor that wears out tires.</TD></TR></TABLE>
so the fact that my front tires are angled 45* in toward my car has nothing to do with the wear being entirely on the inside edge?
riiiighhht.... /yourself
I just wanted to know what a good front kit is i guess, skunk or omnipower or are they pretty much all the same ****?
Old Jul 24, 2006 | 06:41 AM
turbotime's Avatar
after some reading i guess it looks like the skunk2pro are the best cause the screws are on the inside of the UCA...
Anyone think there is a better one?
blk94gsr
Suspension & Brakes
Feb 15, 2006 08:49 AM
blk94gsr
Feb 11, 2006 07:23 PM
fafsa
Apr 6, 2005 03:41 PM
93dx--hatch
Feb 19, 2003 10:01 AM
