f22b1 + h22 tranny what speed sensor?
Old Jul 23, 2006 | 02:38 PM
honda3x23's Avatar
Default f22b1 + h22 tranny what speed sensor?
the h22 trannys speed sensor has these 2 hoses on it what are they for? (shown on right side of pic)
i used teh f22 sensor because of this and my speedo is roughly 5 mph off, will the h22 speed sensor fix this?
Old Jul 23, 2006 | 05:30 PM
stinker504's Avatar
The VSS on that tranny was also used as a pump for something else in the prelude. People that swap the H series into the F23 uses the F23 VSS. It should give you the proper MPH.
Old Jul 23, 2006 | 06:05 PM
NormanBates's Avatar
Default Re: f22b1 + h22 tranny what speed sensor? (honda3x23)
That VSS is actually called a power steering speed sensor. It is controlled hydraulically.
Old Jul 23, 2006 | 06:15 PM
honda3x23's Avatar
hmm well wtf
Old Jul 23, 2006 | 07:32 PM
momstaxi's Avatar
Default Re: (honda3x23)
just loop the hose from one port to the other...
ive never heard of the different vss making the speedo off, but i just used the f22 on in my h trans
Old Jul 23, 2006 | 10:09 PM
philadd's Avatar
Default Re: (momstaxi)
I think I remember B_ron (don't remember his exact sn) saying he has to swap to the H22 VSS in order to get his speedo to read correctly. I don't have any experience with this, so take my post with a grain of salt.
Old Jul 23, 2006 | 10:39 PM
honda3x23's Avatar
hopefully someone else remembers this b ron dude or someone else with similar results
Old Jul 23, 2006 | 10:59 PM
xamraci's Avatar
would the speed sensor be gearing relative? Due to the difference in gearing the speed sensor might be off, as the h22 trans has much different gear ratios from gear to gear, that box is Speed sensative power steering. use the h22 speed sensor...and you should be fine.
Old Jul 24, 2006 | 08:16 AM
honda3x23's Avatar
hmm okay, i will try to get it in today....... its not really the easiest thing to get to
Old Jul 24, 2006 | 12:03 PM
ayougo's Avatar
dam shiney clean that bitch !!!! BTW, those two hoses connect to the powerstearing on preludes. You need to loop them before you install the tranny. Use your F22 vss. It should be fine. Also, if the tranny was sitting for a while, it will be stuborn the first 50 miles or so till the oil gets all up in it. Once installed....YOU"LL LOVE IT !!!! Thats an H22 tranny ? not H23 right ? If so you'll have a new top speed of 115 mph. H23 Top speed is 126
Old Jul 24, 2006 | 12:31 PM
honda3x23's Avatar
see alex, your speedo is off too!!!!
if you use a calculator, in 5th gear you should be going 122 at only 6100 rpm
Old Jul 26, 2006 | 11:42 PM
honda3x23's Avatar
h22 speed sensor fixed my speedo!!!!
god was that a bitch to change!!!!!!!!!!!!!!!!!!!!!!
someone should archive this
732xghost
Nov 14, 2008 02:44 PM
deucedeuceEK
Jun 26, 2006 09:28 AM
pROjECt_D-sOL
Aug 23, 2005 12:49 PM
