Refinishing your oem syncro sleeve
Old Jul 23, 2006 | 09:58 AM
Mr. Tech's Avatar
Default Refinishing your oem syncro sleeve
If you guys know how a syncro and the sleeve work, maybe you will understand me. I purchased a new carbon syncro set, the WHOLE thing, and i remember the last time i checked, the syncro sleeve was a lil worn, i was wondering if you can refinish them maybe with a dremel and make them sharp again? The concept seems to work.. what are your opinions
Old Jul 23, 2006 | 01:00 PM
SkRiBLaH's Avatar
Default Re: Refinishing your oem syncro sleeve (Mr. Tech)
i asked a guy at a local transmission shop the same thing (makes sense) and he said yea you can do that to buy you some time. but i would assume it would work for a while
Old Jul 23, 2006 | 01:18 PM
IN VTEC's Avatar
I haven't found a good, fast way to file the burrs/deformations down and define the teeth better yet. It's a pretty tedious job because the synchro sleeve and hub seem to be hardened and it's so hard to get a good angle on where it needs to be worked.
Old Jul 23, 2006 | 02:16 PM
FIGARILA's Avatar
Default Re: Refinishing your oem syncro sleeve (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">I haven't found a good, fast way to file the burrs/deformations down and define the teeth better yet. It's a pretty tedious job because the synchro sleeve and hub seem to be hardened and it's so hard to get a good angle on where it needs to be worked.</TD></TR></TABLE>.....when i replaced my gsr 4th gear sleeve set i tried it and messed up my file. Not really worth it, if you file to much MATL away it will start pop out of gear.
mpham529
Nov 6, 2008 08:03 AM
My_EFsedan
Paint and Body
25
May 6, 2007 09:25 AM
MARVNVRAM
Mar 19, 2006 08:03 PM
JDMroyEG5turbo
Suspension & Brakes
Feb 11, 2006 08:30 AM
ScareyH22A
Honda Motorcycles
26
Jan 15, 2005 03:43 PM
