replacing a starter and teeth question???
Old Apr 22, 2002 | 12:22 PM
jared3's Avatar
Default replacing a starter and teeth question???
Starter problems... my 88 CRX just spins when I try to start it. Like the teeth are meesed up inside. Is there a way to check that out. And is it hard to change a starter at home? Is there a web page with these kind of instructions?
thanks
Old Apr 22, 2002 | 12:41 PM
EGh22aEG's Avatar
Default Re: replacing a starter and teeth question??? (jared3)
im not really sure how you could fix the teeth maybe the teeth on the flywheel got messed up but changing a starter at home is easy there is the ground the power wire and the two bolts holding it on
Old Apr 22, 2002 | 05:25 PM
B16ED4G's Avatar
the bendix is prob. When you turn the key, the starter spins, but is not being kicked out by the solenoid, in other words, replace the starter
Chris
Old Apr 22, 2002 | 05:54 PM
civbeater90's Avatar
Default Re: replacing a starter and teeth question??? (B16ED4G)
yeah i agree sounds like your starter is bad.same thing happened to my boy's crx
Old Apr 23, 2002 | 06:46 AM
jared3's Avatar
So to replace the starter, it looks like I could go in through the top of the engine? Are there any hoses that I should remove to make it easier, or should I not do anything like that?
Old Apr 23, 2002 | 06:58 AM
keithv's Avatar
you might wanna remove your intake arm to get to the starter easier...
Mdg5858
Feb 9, 2009 12:08 PM
NSXRguy
Dec 24, 2008 12:25 PM
WTB AUTO EK
May 12, 2005 06:46 AM
