Is it possible for clutch to slip alot more when warmed up?
Old Jul 23, 2006 | 07:35 AM
vtec25's Avatar
Default Is it possible for clutch to slip alot more when warmed up?
My clutch seems to grab pretty good at the begining of the morning but after like 20mins of driving it starts to slip more.
Old Jul 23, 2006 | 10:18 AM
non-VTEC's Avatar
Default Re: Is it possible for clutch to slip alot more when warmed up? (vtec25)
ya heat will cause it to slip especially if its worn out.
Old Jul 23, 2006 | 01:24 PM
b18sihatch's Avatar
i second that, i had a clutch do the same thing upon start up the clutch would grab real good. and then when driving it for a few minutes like 20 or so. the clutch would periodicly start to slip then grab.... then slip then grab, bot in that order but it would do it. pulled the clutch and the disc was worn out.
Old Jul 23, 2006 | 05:21 PM
96 GSR-T's Avatar
Default Re: Is it possible for clutch to slip alot more when warmed up? (b18sihatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">i second that, i had a clutch do the same thing upon start up the clutch would grab real good. and then when driving it for a few minutes like 20 or so. the clutch would periodicly start to slip then grab.... then slip then grab, bot in that order but it would do it. pulled the clutch and the disc was worn out.</TD></TR></TABLE>
My stock ITR clutch was like that, when it had 10k on it. My ACT now feels exactly the same hot/cold unless I slip the hell out of it.
Old Jul 23, 2006 | 06:31 PM
JDMtype Eg6's Avatar
whats weird is that my clutch is the opposite. While the engine is cold the clutch would slightly slip but when my car is warmed up it grabs fine. is this normal or is it a sighn of a bad clutch? sry vtec25 if im thread jacking hah.
Old Jul 23, 2006 | 07:51 PM
vtec25's Avatar
Default Re: (JDMtype Eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMtype Eg6 &raquo;</TD></TR><TR><TD CLASS="quote">whats weird is that my clutch is the opposite. While the engine is cold the clutch would slightly slip but when my car is warmed up it grabs fine. is this normal or is it a sighn of a bad clutch? sry vtec25 if im thread jacking hah.</TD></TR></TABLE>
No prob man. Is it a stock clutch?
Old Jul 24, 2006 | 01:48 PM
Default Re: (vtec25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec25 &raquo;</TD></TR><TR><TD CLASS="quote">
No prob man. Is it a stock clutch?</TD></TR></TABLE>
yup its a stock clutch, but this happens about half the time. usually grabs fine at startup
Old Jul 24, 2006 | 03:04 PM
usually happens when temp is cold outside
Old Jul 25, 2006 | 06:35 AM
b18sihatch's Avatar
how many miles on the clutch? what kinda driving has it seen
Old Jul 25, 2006 | 07:04 AM
trickeng's Avatar
Default Re: (b18sihatch)
heat will aid slippage...
Old Aug 4, 2006 | 10:44 PM
vtec25's Avatar
Default Re: (trickeng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trickeng &raquo;</TD></TR><TR><TD CLASS="quote">heat will aid slippage...</TD></TR></TABLE>
HELL YEAH! WOW these past few days its been like 102 degree's out and wow my **** feels like its almost completly fried. But now its back to its normal slipping now that its down to the 80's.
globy123
Nov 29, 2007 11:21 AM
cats_on_ice
May 25, 2006 07:25 AM
Brett
Feb 12, 2003 04:26 PM
