could i add my cams if....
Old Jul 23, 2006 | 06:35 AM
jennsGSR's Avatar
Default could i add my cams if....
could i add my cams if i havent chipped the ecu? and.. if i have a vafc2 could i control it that way? i really wanna add my cams but eeryone says wait till i chip the ecu.. what do ya think?
Old Jul 23, 2006 | 07:14 AM
lsvtek's Avatar
Default Re: could i add my cams if.... (jennsGSR)
actually, the way i thought it was is, you first add cams then you chip it so it is tuned and all, also are you just going to put cams in it and nothing else changed? Im wondering because I would like to change my camshaft also with crower 403
Old Jul 23, 2006 | 07:40 AM
lVlemphizStylez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jennsGSR &raquo;</TD></TR><TR><TD CLASS="quote">could i add my cams if i havent chipped the ecu? and.. if i have a vafc2 could i control it that way? i really wanna add my cams but eeryone says wait till i chip the ecu.. what do ya think?</TD></TR></TABLE>
yes it can be tuned with the vafc...but because cams are so picky with ignition timing AND fuel...you wont see good results because piggybacks arent independent of ignition settings with fuel...(you lean you advance...you richen you retard, thats the only way itll let you adjust)
Old Jul 23, 2006 | 08:01 AM
jennsGSR's Avatar
Default Re: could i add my cams if.... (lVlemphizStylez)
no i already installed the valve springs and retainers
Old Jul 23, 2006 | 08:15 AM
mmuller's Avatar
Mad Scientist
you sure can do it, it obviously depends on wat cams your planning in using.
tuning is a must to get max power out of them.
stock maps run pretty rich up to so you have a pretty big window to play
Old Jul 23, 2006 | 08:32 AM
jennsGSR's Avatar
Default Re: could i add my cams if.... (mmuller)
ok, so if i add my cams, dont chip the ecu, what should i do with my vafc2 to help it run ok. ?
Old Jul 23, 2006 | 08:37 AM
mmuller's Avatar
Mad Scientist
sell it and get crome and a wideband.
then youll be able to do something about it. VAFC is a very very crude but bling bling way to kinda tune your AF only.
tuning timing is where the money is at.
Old Jul 23, 2006 | 08:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">sell it and get crome and a wideband.
tuning timing is where the money is at.</TD></TR></TABLE>
exactly...fuel tuning not independent of ignition is kinda obsolete...
Old Jul 23, 2006 | 09:12 AM
Nevets's Avatar
VAFC's are a thing of the past.
Old Jul 23, 2006 | 11:33 AM
DC2SIR-G's Avatar
* B A N N E D *
Default Re: could i add my cams if.... (Nevets)
drop the cams in first. then when u have $4 get a chipped p28
motormike40
Dec 26, 2007 10:21 AM
bigplansnocar
Sep 26, 2003 08:12 AM
DualCamEK
Apr 1, 2003 09:58 PM
