abs light
I have a 95 4 door integra gsr and when i get any kind of wheel spin our wheel hop my abs light comes on and my car starts to bog down. Is there a way to fix it, i search a little bit and found that to clean it helps. Does any one have any ideas our heard of it before and know how to disable it.
Your abs light will not make your car bog down, you have another problem that needs to be looked at. Like you said, clean the ABS sensor and the light should go away regardless of whether your engine is under load or not.
