hesitation when i give it gas need help
Old Jul 22, 2006 | 09:34 PM
I_LOVE_HONDAS's Avatar
Default hesitation when i give it gas need help
I have a 01 gsr and this problem just started when you are going down the road and you hit the gas the car acts like it is hitting the rev limiter. The only time i can get it to do it is when i am like lugging a little bit and give it more gas it starts doing this. I dont have a clue what it is but i need help fixing the problem. The car runs fine when if your not lugging but i can barely be lugging not enough to shift down and give it gas and it does this
Old Jul 22, 2006 | 09:44 PM
watsvtecEK's Avatar
Default Re: hesitation when i give it gas need help (I_LOVE_HONDAS)
mine dose the same thing. like your just luggin it and all of a sudden it jumps like it got no fuel.. freakin anoying. whatsyour set up?
Old Jul 25, 2006 | 08:32 AM
Default Re: hesitation when i give it gas need help (D 2da A9)
It has 2.5 catback on it 4 to 1 header and a intake its also lowered and 8.5mm wires
Old Jun 5, 2007 | 05:08 PM
909rex's Avatar
same problem here with an LS
Old Jun 5, 2007 | 06:34 PM
AdiDAsi's Avatar
change the spark plugs. clean your injectors.
Old Jun 6, 2007 | 07:09 AM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: (HrdparkHater)
Not sure, but try tightening your throttle cable... It gave me a better throttle response so I would try that...
Old Jun 6, 2007 | 07:11 AM
JdmHondaGirl's Avatar
Dang it! I suck at making stuff up!
Default Re: (Project95LS-VTEC)
If its not the trottle cable (like in my case) change the spark plugs!!!
Worked for me
Old Jun 6, 2007 | 11:39 AM
Rice-aronie's Avatar
Default Re: (JdmHondaGirl)
spark plugs, fuel filter, distributor cap and rotor. It's a start. So basically a minor tune-up.
toshko321
Oct 18, 2009 07:15 AM
MyEfSi2Slow
Mar 9, 2008 06:42 PM
llTysonll
Sep 12, 2005 03:29 PM
social_control
Aug 31, 2003 10:25 AM
