trying to track down hatch leak...are there seams on the roof?
Old Jul 22, 2006 | 09:05 PM
drew2's Avatar
Default trying to track down hatch leak...are there seams on the roof?
the drivers side of the back of my 90 hatch leaks. I have been unable to trace the leak. i cleared the sunroof drain lines on both sides. the water fills the pocket in the plastic the the hatch cover clips in. I can see it dripping down where the handle to pop out the back window is. where is this water coming from?
i bought a new seal for the rear driver window from honda but it doesn't fit, i tried putting it in about 5 times and its too big. triple checked the part numbers and its the right one. im hesitant to buy another seal b/c i dont know what that one hasn't worked.
where is this water coming from? tried using a hose to find out but to no avail
Old Jul 22, 2006 | 09:20 PM
Tippyman's Avatar
Tailights gaskets?
Old Jul 22, 2006 | 09:44 PM
drew2's Avatar
Default Re: (Tippyman)
its leaking from higher up than the taillights i believe, since it drips thru where the window handle is
Old Jul 23, 2006 | 09:10 AM
CRX1.4DualCarb's Avatar
Ok, I have a similar problem in my CRX. Water drips on the inside on top of passenger seats. it crips from the sides, from the trunk shock mounts. I know this because I removed the liner and plastics. Before that it would just run down in to the back, and into the wheel weel.
It came down to be a crack in the roof!! On both sides of the roof, right after the weather strip there is some kind of filler between the body panels. It has cracked. I could barely see it because the trunk would cover it. I just scraped some, and covered it wiyh silicone.. done. ;-)
Old Jul 23, 2006 | 11:44 AM
drew2's Avatar
Default Re: (CRX1.4DualCarb)
hmmm, sounds lke that could be my problem, im not sure what you mean by "after the weather stripping" . under it? should i take the strip off on either sides and check for leaks? how is it attached, is it easy to replace?
Old Jul 23, 2006 | 02:25 PM
drew2's Avatar
Default Re: (drew2)
anyone? what are under the trim strips that run in the grooves down either side of the roof? how are those trim strips attached?
Old Jul 23, 2006 | 10:08 PM
speedKILLS's Avatar
Default Re: (drew2)
The weather strips can be removed by simply taking a flat head screw driver and gently pulling up under the stripping. It's easier to start from the back because the weather stripping from the front windshield often covers the front. I want to say there is some little metal tabs on each side of the stripping.
lancerkid06
Mar 6, 2009 08:27 AM
mycrxsi89
Aug 15, 2008 04:54 PM
CRXDaddy78155
Jul 7, 2007 04:05 AM
green91
12
Feb 1, 2006 11:00 AM
yusoslo
12
Oct 22, 2003 09:03 PM
