NO fuel and no spark
Old Jul 22, 2006 | 08:00 PM
gsutke458's Avatar
Default NO fuel and no spark
A few weeks ago my car wouldnt crank out of the blue. I checked and had no spark so i replaced the destributor. After that the car cranked, however two days later it did it again, and would not crank at random. This time it wasnt getting fuel. So i put in a new pump. After that still would crank i replaced the relay for the second time in two years. what is left. Is it the ECU, or could it be something else. Thanks for any hellp
Old Jul 23, 2006 | 02:11 AM
Bodhi's Avatar
Default Re: NO fuel and no spark (gsutke458)
Was it really hot outside? I'm having similar problems that typically happen when it's fairly hot outside.
Old Jul 23, 2006 | 07:38 AM
kpop's Avatar
Default Re: NO fuel and no spark (Bodhi)
try the main relay
Old Jul 23, 2006 | 10:29 AM
gsutke458's Avatar
Default Re: NO fuel and no spark (kpop)
replaced it already
Old Jul 23, 2006 | 11:07 AM
InfamousDC2FI's Avatar
check your fuses under your dash, specifically any of them that have to do with ignition
Old Jul 23, 2006 | 12:27 PM
Twilightepitaph's Avatar
Default Re: NO fuel and no spark (InfamousDC2FI)
If you have a friend or know someone that has the same car you might see if they will let you borrow their ecu to check it. I know someone had a simmilar problem a while back and i think that was the issue but im not sure. You might also find one cheap at a junkyard. Also you might check around for wires that might be grounding out and frying out your stuff. Thats all i can think of. Good luck.
keslerbuilt
Jan 26, 2014 09:50 AM
95turboeg
11
Jun 13, 2013 03:51 PM
cartech1
Feb 6, 2013 08:47 AM
bronxbomber0215
14
Nov 20, 2007 10:48 PM
utahcoheed
36
Sep 6, 2007 03:06 PM
