which fuse to pull to disable ABS on 94 EX?
hi my ABS accumulator is broke and makes a buzzing noise when i start up the car. i do not have the money to replace it so i just going to disable ABS so itll go away. the abs isnt working anyways so might as well get rid of the noise and light
so which fuse do i pull to disable ABS?
the ABS has it's own little fuse box on the passenger side fender well. But you won't get rid of the ABS dash light without; #1remove the bulb or #2 get a schematic and clip the wire that powers the bulb.
A lot of times the check valve gets full of crud and the pump won't hold pressure; it might be worth the effort to bleed the ABS unit and get some fresh fluid in it.
Make sure the abs modulator reservoir is full of brake fluid. Usually if the pump continues to run, its low. Fill it up. If that doesn't work, remove the relay for the abs pump in that little fuse box. Easiest way to quiet the pump.
ArchAngel Sabastian
Jan 20, 2003 04:49 PM
