2003 accord ac drain?
Old Jul 22, 2006 | 03:28 PM
dave f's Avatar
Default 2003 accord ac drain?
help...I've got a 2003 accord with 3.0...when you run ac [ice cold]no water drips from under car but passenger footwell soaking wet...possible clogged drain line? also where is it located? thanks dave f.
Old Jul 22, 2006 | 08:01 PM
V6iCkSpEeD's Avatar
Default Re: 2003 accord ac drain? (dave f)
The a/c drain hose it located by the right front of the catlytic converter, its a little black rubber hose and there should be a cutout for it on the heat shield if i remember right. I know on the 4cyl it is like this because when you are changing the oil the water is constantly dripping on your head. On the V6 i am not really sure but it should be the same.
Old Jul 23, 2006 | 02:52 AM
YeuEmMaiMai's Avatar
located on passenger side of car. If you are under the car you should see the hose comming out of the floor pan right behind the firewall.
#20 in the illustration
Old Jul 23, 2006 | 04:29 AM
dave f's Avatar
Default Re: 2003 accord ac drain? (V6iCkSpEeD)
thank you for your time and help, found it and unclogged it...dave f
Old Jul 23, 2006 | 04:32 AM
dave f's Avatar
Default Re: 2003 accord ac drain? (YeuEmMaiMai)
thanks for your time, help and illustration, i was able to find it and unclog it. dave f
Fixit-13
Honda Accord (2013 - 2015)
Oct 19, 2017 04:38 AM
Craigc187
Aug 31, 2015 12:18 PM
Frank Howard
Feb 20, 2014 03:47 PM
thequesogrande
Jun 26, 2013 09:56 PM
96AccordMD
Jun 16, 2009 10:38 AM
