95 accord swap now starts but die
Old Jul 22, 2006 | 01:25 PM
lv6l's Avatar
Default 95 accord swap now starts but die
i'm dealing with a 94 accord ex. i just swap the motor to the same one but jdm. f22b. i'm using tranny from 90-93 accord. the motor cranks, starts but die out afterwards. holding down gas pedal let it start for about 1 sec longer but still dies out. i have check the distributor and its fine, compression is cyl 1: 170 cyl 2: 190 cyl 3: 170 cyl 4: 195. the timing belt was not taking off but the tensioner bolt was loosen but my friend and i remember no teeth was skip and now it is tight. we also check number 1 piston at highest point and it lines up with TDC on crank pully. what could be the problem. thanks.
95_accord
Oct 17, 2007 03:23 AM
f22suzuka
Dec 26, 2003 05:09 AM
vsmex99
Sep 26, 2002 11:21 AM
