after market gauge cluster won't light up?????
Old Jul 22, 2006 | 10:20 AM
95bkeg's Avatar
Default after market gauge cluster won't light up?????
95 civic ex bought the car with the white face gauges in it already and only drove it in the day so I didn't notice them not lighting up. I took the wholke dash apart and everything is hookek up right. have it running on a 10 amp fuse with a add a fuse adapter hooked into the stock gauge light fuse (stock back lighting works fine) they go on every now and then when I hit a bump (starting to sound like it might be a bad ground connection) I don't know the brand or model but you can change the color of the lighting if that helps anyone narrow down which one I have. Any input would be great!!
thanks
Old Jul 22, 2006 | 10:27 AM
birds_sol_94's Avatar
Default Re: after market gauge cluster won't light up????? (josh's civic)
yea i bought some of those for mine... pieces of ****.. haha mine was wired up right .. well how they say to wire it.. and they would work when they wanted to ... and didnt work when they wanted to.. so i took them out.. and trashed them.. haha
Old Jul 22, 2006 | 11:54 AM
ballerchild's Avatar
Default Re: after market gauge cluster won't light up????? (birds_sol_94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by birds_sol_94 &raquo;</TD></TR><TR><TD CLASS="quote">.. so i took them out.. and trashed them.. haha</TD></TR></TABLE>
listen to this guy.
Old Jul 22, 2006 | 12:34 PM
matt56's Avatar
yea i have the same problem with my white face guages. when i bought my car thay worked fine for about a week then started flickering on and of when i hit bumps and so i started shaking the wiring under my dash and it kept coming of then off and finaly just stayed off for good and i dont know how to fix it. so if anyone knows anything about this please let me know.
Thanks
Old Jul 22, 2006 | 01:24 PM
user 6297290's Avatar
Default Re: after market gauge cluster won't light up????? (matt56)
I wish people on this site would learn that people are allowed to do whatever they want to their cars, if you can't help out then don't post...
Now, to help you out matt and the OP, the same thing happened to me, I got my car used and had a set in. after a few weeks mine died as well. I found out the little power supply / color change controller died on me. So I just went out and got a new set on ebay for 30 bucks and they have been working flawlessly for the past 3 years. So that could be something to look at, make sure the power box is actually working, get a volt meter and make sure power is flowing thru it. hope this helps
Old Jul 22, 2006 | 01:39 PM
matt56's Avatar
Default Re: after market gauge cluster won't light up????? (mr twig)
thanks for the help mr twig oh and i dont have a color changer on mine but i do have a little controller to make it brighter or dimmer, do you think that would cause them to stop working if it went out? oh and what does the power box look like? sorry i dont know anything about guage clusters/wiring.
Thanks
Old Jul 22, 2006 | 02:50 PM
it's possible that the dimmer could be bad and not letting the electricity flow thru it. on mine I had a little black box that basicly the guage faces and the dimmer/color changer plugged into and from that the power wires came out of it.
you can probably just use any dimmer switch at any electronics store, it basicly functions the same as a dimmer switch you would have in your house for lights - except the one in your car is a lot smaller. if not try bypassing the dimmer all together and just hook up the power directly to see if you can get it to work with a constant brightness. if it still doesnt work then something is burnt out and time to hit up ebay.
hope this helped
GroundZer0 336
Jun 26, 2010 07:02 PM
91hatchcivic
Apr 13, 2008 02:55 PM
enzozenuni
Dec 24, 2006 12:20 AM
jdmilf
12
Jun 2, 2005 03:26 PM
