help! 98 accord p0171-p0170
Old Jul 22, 2006 | 02:00 AM
civicracer94's Avatar
Default help! 98 accord p0171-p0170
i have been working on a friends 98 accord 2.3vtec its getting these codes
1 p0171--fuel trim malfunction
2 p0171--system too lean bank 1
i have been all over this car i cant seem to fine out what it is
here's what i have done new fuel pump new- fuel pressure regulator new plugs wires i was going to change the filter but it dont have one witch seem odd to me but anyway you have any ideals ?a few people i have talk to said it might be an 02 sensor but wouldn't it throw its own code ?
Old Jul 22, 2006 | 12:57 PM
Default Re: help! 98 accord p0171-p0170 (civicracer94)
bump anyone ??
Old Jul 22, 2006 | 01:02 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Usually the Mass Air Flow sensor just needs to be cleaned.
http://www.obd-codes.com/troub...r.php
I recently cleaned my dad's Toyota MAF sensor, and it fixed the problem. Car ran better after that.
Old Jul 22, 2006 | 01:17 PM
philadd's Avatar
Default Re: help! 98 accord p0171-p0170 (tech8)
6th gen Accods have MAP sensors, not MAF sensors, but I suppose the same thing would apply.
Old Jul 22, 2006 | 02:31 PM
Default Re: help! 98 accord p0171-p0170 (philadd)
as far as i know all accords have maps but i never heard of a map being dirty i did try searching but didnt find anything even google and nothing just found out that alot of people have the same problem
Old Jul 24, 2006 | 05:40 PM
CARMandP's Avatar
I would start by replacing the o2 sensor. Most likely its reading slow. There was a bulletin about the fuel pressure regulator going bad but you already replaced that. I have seen the o2 sensor get lazy and read wrong causing the code. Usually the computer will try and compensate the fuel injector duration to try and fix a bad o2 sensor reading and it causes this code.
breny
Jan 31, 2013 08:00 PM
Mr Gsxr
Jun 11, 2012 03:02 AM
angelyno55
Jan 20, 2012 01:39 PM
