bell housing has oil in it, okey?
Old Jul 21, 2006 | 08:11 PM
BfromSD's Avatar
Default bell housing has oil in it, okey?
hey I just slap my turbo kit back on my 2000 civic si and I had all sorts of leaks. Oil pan gasket, turbo return, and crank case vent system. anyways the oil pan gasket was leaking on the tranny side and in an effort to quick fix it I took the sheld off the lower part of the tranny so the flywheel is exposed and when I was driving oil must have got on the flywheel spun off probley putting a nice coat of oil in the bell housing. should I take the tranny off and clean it or will it have no effect on the longevity of the clutch?
my set up made 430hp/305tq at 8000rpms on crome- Lsvtec stock head, rods, sleeves.
hears a pic form the install[IMG][/IMG]
Modified by spicyEM1 at 9:49 PM 7/21/2006
Old Jul 21, 2006 | 09:47 PM
BfromSD's Avatar
Default Re: bell housing has oil in it, okey? (spicyEM1)
Old Jul 22, 2006 | 07:47 AM
BfromSD's Avatar
F it im gonna put it back together and take it off the jacks
Old Jul 22, 2006 | 09:12 AM
thesmogman's Avatar
Since your a Diegoian, check your rear seal for the crank. That is what usually muck's up the bellhousing/clutch.
Old Jul 22, 2006 | 01:36 PM
SteveoBA8's Avatar
Default Re: bell housing has oil in it, okey? (thesmogman)
yep rear main would be the 1st thing i look at
Old Jul 22, 2006 | 03:12 PM
BfromSD's Avatar
Default Re: bell housing has oil in it, okey? (SteveoBA8)
the main seal is good, the oil pan was not torqued back to spec when I taped the oil pan. It's been fixed with hondabond and a new gasket.
ImPuLsIvE
Oct 29, 2008 06:44 AM
frozenrice
Aug 7, 2007 04:15 PM
Mr. Vapor
Mar 13, 2006 08:12 AM
Mr. Vapor
Mar 13, 2006 08:04 AM
geminis2k
Mar 29, 2004 08:00 PM
