Does anyone make a motor mount kit for a 98 dx?
I am dropping a ls/vtec into my 98 civic dx and want a motor mount kit but I am unable to find one. Does anyone know what motor mounts I need to get for this swap if there isn't a motor mount swap kit????
Thanks
Thanks
if i'm not mistakin, you would use stock honda/acura mounts to swap in your motor, if you are using a b series block for the ls/vtec.. unless your talkin bout the motor mount inserts, then you would get the one for the civic.. hope this helps..
but for what car?? Do i just use my stock 98 civic dx mounts or do i get 2000 si motor mounts??
http://www.jspectuning.com
that'll tell you what mounts to use then get the insert kit for those mounts....
Knightmare69
May 5, 2004 08:00 PM
JDubya
Oct 7, 2002 01:32 PM
