h23 tranny on f22... help
Old Apr 22, 2002 | 08:52 AM
allshownogo7's Avatar
Default h23 tranny on f22... help
i hate my automatic tranny... im plannin to go manual whenever i find a good price but before that i need some information. i read a FAQ's on h22's & i have some questions.
when going f22 to h23 tranny:
"While your acceleration will imporove substantially, your top end will suffer greatly. The f22 doesn't have the same kind of headroom as the h22. You'll run about 1.5k from redline at highway speeds. So if you travel long distances, a tranny swap alone isn't such a good idea."
could anybody xplain that a little bit more. thanx!
should i do it? since there are drawbacks...
[Modified by allshownogo7, 3:50 PM 4/22/2002]
Old Apr 22, 2002 | 11:39 AM
SOHCArchangel's Avatar
Default Re: h23 tranny on f22... help (allshownogo7)
let me be the first to say
your post makes no sense and ill explain why, observe:
1) all f/h trannies are interchangeable on all f/h motors
2) all f/h trannies do not share the same gearing between each other
3) the h23 has the same gearing as a 5 speed f22 with exception of fd possably
4) go back to the person that told you that and ask him if he has any dehydrated water or a cold fusion reactor
Old Apr 22, 2002 | 11:42 AM
Gennady's Avatar
New User
Why not just use an Accord 5-speed?
Old Apr 22, 2002 | 12:35 PM
TypeSH's Avatar
Default Re: h23 tranny on f22... help (SOHCArchangel)
no the h23 tranny has significantly shorter gear ratios than the F22 tranny (depends on which F22 you are refering to, there are half a dozen variants of the f-22 tranny).
What cryogen was refering to, is the fact that at 80mph, you will be running at close to 4k rpms (or 4400rpms for an h22a tranny), which i guess in his opinion is too high for long trips on open highways. Thats why he recommended against it if you make long drives at high speeds.
More revs = more wear on motor, so you would be stressing the motor more on long trips compared to using the f22 tranny (80 at what, 3000rpms?).
I am considering a h23a swap as my 5th gear syncho is now shot, =|. But then again I'm not a speed freak so I dont mind driving at only 70mph w/ the h23 tranny and keep the rpms closer to crusing rpms of the f22 tranny.
Old Apr 22, 2002 | 12:47 PM
Gennady's Avatar
New User
Default Re: h23 tranny on f22... help (TypeSH)
At 80mph I'm @ around 3500rpm.
Old Apr 22, 2002 | 12:53 PM
Accord94DX's Avatar
Bwahahahahahahahahaaahahahhahaha!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!
Old Apr 22, 2002 | 01:22 PM
speck102's Avatar
Default Re: h23 tranny on f22... help (Accord94DX)
On my celica my rpm was at 4k when I was going 80, on my accord it's under 3500. 4k is not that high.
Old Apr 22, 2002 | 02:39 PM
H23 Power's Avatar
*cough* *choke* * cough*
lets look here for a minute
final drive 4.06:1 (man) 4.27:1 (man)
I 3.31 3.31
II 1.81 1.86
III 1.23 1.32
IV 0.90 1.03
V 0.71 0.81
f22 on the left...H23 on the right
Old Apr 23, 2002 | 10:42 AM
Stew Pidasso's Avatar
My '87 Accord goes 80 MPH @4000 RPM in fourth gear .
Old Apr 23, 2002 | 12:20 PM
H23 Power's Avatar
Default Re: h23 tranny on f22... help (Nitz5785)
indicated 80 mph for me is 3900 rpm in 5th...but an acurate 80 mph is actually closer to 4400 rpms...because of front tire size
Old Apr 23, 2002 | 12:30 PM
Default Re: h23 tranny on f22... help (01GSR)
dave and i have a spread sheets of all f/h gearing, im sorry i couldnt rember them off the top of my head
Old Apr 23, 2002 | 05:14 PM
Nick H's Avatar
New User
don't forget to ask about the hole remover and muffler bearings while your at it!...lmfao
lulu13815
May 6, 2006 12:29 AM
Shane08
Mar 10, 2006 01:26 PM
LsPoweredEF
Mar 3, 2004 08:37 AM
blackcd
Feb 19, 2003 10:46 AM
honda8882
Aug 27, 2002 07:53 AM
