Help Need info on a H22 Swap into a 98 Accord
Hi,
Can anyone tell me which motor mounts can I use or keep for my H22 Swap into a 98 Accord. I am swapping a auto into a auto because my tranny died.
Thanks
Thanks
6th gen isn't in there- I've been trying to see how much of a pain this would be. still working on the tranny part of it with the issues with the immobilizer.
Swaps
H22A Swap into a 4th Gen
H22A Swap into a 5th Gen
H22A Swap FAQs
F22B1 VTEC Headswap
H22A Head Swap onto a F23A1 Block
H22A1 Head Swap onto a F22B2 Block
H23A1 Head Swap onto a F23A1 Block
H22A Head Swap onto a H23A Block
Swaps
H22A Swap FAQs
F22B1 VTEC Headswap
if you use an ecu from another 6th gen accord.. then you will have problems with immobilzer. You can use any odb1 ecu and you be good.
your guide to h22 into a 6gen --> http://www.everything-honda.co...ge=22
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by npcanibus3 »</TD></TR><TR><TD CLASS="quote">if you use an ecu from another 6th gen accord.. then you will have problems with immobilzer. You can use any odb1 ecu and you be good.
