Replacing 98 accord wiper switch help!!!
Old Jul 21, 2006 | 12:42 PM
chomorro's Avatar
Default Replacing 98 accord wiper switch help!!!
How easy is this procedure? Does the steering wheel or air bag have to be removed? My switch looks like its glued shut for my wiper fluid, but everything else works perfect. Should i attempt at unsticking the switch??
Old Jul 21, 2006 | 05:50 PM
hondadude's Avatar
Default Re: Replacing 98 accord wiper switch help!!! (chomorro)
remove the steering column shroud, then you'll have to turn the steering wheel to get to a screw, and then there is a tricky clip on the back. [pry out the case with a small screwdriver] ta daaa, old switch is gone
Old Jul 23, 2006 | 10:35 AM
chomorro's Avatar
Default Re: Replacing 98 accord wiper switch help!!! (hondadude)
sounds easy enough. thank you
sgwood
Aug 17, 2008 10:02 AM
JLefevers
Jan 4, 2008 05:09 PM
civic-one
Jul 26, 2007 02:42 PM
f22b2tdave
Jul 30, 2006 12:41 PM
