94 civic wierd problem?!
Hey Ok i have a 94 civic coupe 5 speed.
Ok the problem I have is whenever I start my car sometimes, I put it in gear and it dies. Then i try to start it and it wont start. I let it sit 5 minutes, then it is fine again...i think its a fuel filter needing replaced. what do you guys think??
-Rob
-Rob
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Main relay going out? It's a common problem.</TD></TR></TABLE>
is that expensive to fix?
could it be something else though>
i thought that usually when the main fuel relay is going your car won't start at all and you can hit it until it finally kicks in
anyway if it is a main fuel relay i think theyre like $60 from honda and it's easy to replace. It's bolted up right under your dash
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amy »</TD></TR><TR><TD CLASS="quote">i thought that usually when the main fuel relay is going your car won't start at all and you can hit it until it finally kicks in
anyway if it is a main fuel relay i think theyre like $60 from honda and it's easy to replace. It's bolted up right under your dash</TD></TR></TABLE>
they do that or they can sparadically cut out and die
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rleonekc »</TD></TR><TR><TD CLASS="quote">is that expensive to fix?
could it be something else though></TD></TR></TABLE>
could be but i would start with the relay ....your car is almost 12 years old now and those relays very commonly die so that where i would start
Einhander276
Jan 15, 2013 08:11 PM
littlestroker
Mar 30, 2005 07:53 PM
