mounting slim fans?
Old Jul 21, 2006 | 11:15 AM
vladd's Avatar
Default mounting slim fans?
i'm not sure how to mount my slim fans on my stock radiator. will zip ties melt? because the fans came with some. some ideas and/or pics would be awesome.
Old Jul 21, 2006 | 12:45 PM
93_teg_CT's Avatar
Default Re: mounting slim fans? (civicdxtyper)
Nah brah, zip ties work fine. I have 4 of them on my halfcore and I've ran it real hard, had it on there for a couple months now and I don't notice anything wrong with em.
Old Jul 21, 2006 | 12:48 PM
Dartanian's Avatar
I used zip ties. They are holding just fine.
Old Jul 21, 2006 | 01:02 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: mounting slim fans? (Sleeper Style)
I am getting ready to go work on my radiator and put a slim fan on. Use one way zip ties. You can get them at any auto parts store. It's like $3 for 4 of em.
Old Jul 21, 2006 | 01:40 PM
vladd's Avatar
Default Re: mounting slim fans? (SlammedDC2)
sweet, thats what i was hoping to hear. thanks guys
Old Jul 21, 2006 | 03:33 PM
vladd's Avatar
ha i just tried mounting them with zip ties and its not working all that great. the locations of the holes on the radiator aren't allowing the fans to sit against the radiator completely flush; they're just kinda bouncing around. if someone took pics when they installed theirs i would really appreciate them being posted up.
Old Jul 21, 2006 | 03:50 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdxtyper &raquo;</TD></TR><TR><TD CLASS="quote">ha i just tried mounting them with zip ties and its not working all that great. the locations of the holes on the radiator aren't allowing the fans to sit against the radiator completely flush; they're just kinda bouncing around. if someone took pics when they installed theirs i would really appreciate them being posted up.</TD></TR></TABLE>
the fans diameter must be larger than the fin portion of the rad. I know the Teg rads can run up to a 14" slim fan. The Hayden fasteners that are kinda like zip ties work great.
EDIT:
Here's a pic of my 14" Hayden slim Fan setup as a pusher
Old Jul 21, 2006 | 04:01 PM
vladd's Avatar
Default Re: mounting slim fans? (skunked)
i have 2 10" fans. somewhere on here people were saying there's no need to go with anything bigger.
Old Jul 21, 2006 | 04:03 PM
Jose-aka-Pedro's Avatar
No need, but better cooling is always better,
get creative and fab some brackets
Old Jul 21, 2006 | 04:10 PM
jdm_bones's Avatar
use the metal type zip tie ftw!
Old Jul 21, 2006 | 06:43 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: mounting slim fans? (jdm_bones)
I have an 11'' and a 10''. Like I said go to orieleys (sp?) and get some one way zip ties. I just finished mounting both of my fans with these on a C&R after I cut the mounting bracket off. The work no problem. Just ask someone there for some one way zip ties. They cost me like $3 and change. You get 4 with 4 little foam pads to mount it just off the fins. I don't have any pics because it is raining like crazy.
Old Jul 21, 2006 | 07:33 PM
iBrandon's Avatar
be sure the fan spins freely when mounted, if not add rubber spacers until it spins freely...i use the zipties..
Old Jul 21, 2006 | 10:42 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: mounting slim fans? (iBrandon)
Used some zip ties, but the pressure from the 2 fans pushing against each other would have be fine too.
The room I saved
Old Jul 22, 2006 | 05:18 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: mounting slim fans? (00IntegrAllmotoR)
Is that setup working okay with the fans having to push air through the A/C condenser first, and then through the radiator, instead of like the stock fans pulling air through the radiator and then the condenser?
Old Jul 22, 2006 | 08:11 AM
SlammedDC2's Avatar
Semper Fidelis
Default Re: mounting slim fans? (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Is that setup working okay with the fans having to push air through the A/C condenser first, and then through the radiator, instead of like the stock fans pulling air through the radiator and then the condenser?</TD></TR></TABLE>
It's working fine for me.
Old Jul 22, 2006 | 02:59 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones &raquo;</TD></TR><TR><TD CLASS="quote">use the metal type zip tie ftw! </TD></TR></TABLE>
what exactly are metal type zip ties? are they the exact same thing as plastic, just metal? never heard of them. and if they're the same thing, how would they be any better? i guess i'm just going to use the regular zip ties for now and if i have problems later on, i'll have to think of something else.
Old Jul 22, 2006 | 03:35 PM
HT Black OPs
If you think about it, the fans have to get air through the condenser first anyways. And in my line of work, "its always better to push then to pull." Plus mine are 12inch fans and push more cfm then the stock ones. Contact b18bturbo on here
EDIT: I did put my bumper support back on, it does not interfere with the fans. It was just easier to work on the car w/ it off.
lsvtecEM1
Mar 19, 2012 05:18 AM
lsvtecEM1
Mar 18, 2012 10:38 AM
95LSS
Jul 24, 2006 06:35 PM
dwolsten
Dec 7, 2002 04:35 PM
4doorH22
Jan 19, 2002 12:12 PM
