ecu
Old Jul 21, 2006 | 10:03 AM
turbogsr181's Avatar
Default ecu
Is it possibly for an ecu to be "fried" or something be wrong with the ecu, and make the car run bad, but still work?
Old Jul 21, 2006 | 11:04 AM
trick_db's Avatar
Default Re: ecu (turbogsr181)
yes it possible
Old Jul 21, 2006 | 11:13 AM
iH8RICERZ's Avatar
Default Re: ecu (trick_db)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trick_db &raquo;</TD></TR><TR><TD CLASS="quote">yes it possible</TD></TR></TABLE>
Your car would run, but run like dookie!
Old Jul 21, 2006 | 11:16 AM
trick_db's Avatar
Default Re: ecu (iH8RICERZ)
haha more like ****
Old Jul 21, 2006 | 12:42 PM
okay good, so im not crazy, thank you. it does run like junk
Old Jul 21, 2006 | 12:44 PM
so what could possibly be wrong with the ecu?
Old Jul 21, 2006 | 01:18 PM
rkrone's Avatar
have you tested anything? codes? sensors? have you swapped out the ecu to see if it is in fact the ecu? there could be so many things
Old Jul 21, 2006 | 02:16 PM
Default Re: ecu (rkrone)
i have had a problem with my car running like **** for a while. when i say running like **** i mean running slow, my ecu that i have in my car now is chipped, but i put a stock ecu in my car that was never tampered with the car ran like it was a complety different car
Old Jul 21, 2006 | 07:02 PM
SOHCD16y8's Avatar
id be looking at the chip that you have in your car, more then likely it is a bad map.
What are you tuning with?
Old Jul 21, 2006 | 09:38 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (SOHCD16y8)
My stock P72 is actually throwing a code (dont remember which one) but it basicly breaks down to "bad ecu" and my car runs like dog ****. I cant wait till I get my new OBD conversion harness so i can go back to my P30.
Old Jul 21, 2006 | 10:22 PM
turbogsr18's Avatar
Default Re: (SlammedDC2)
mine doesnt throw any codes
erikiksaz1
Engine Management and Tuning
Jun 11, 2010 02:39 PM
§95HATCH§
May 16, 2009 07:19 PM
egbaby
Feb 24, 2008 12:30 AM
ef_you_again
17
Mar 28, 2005 07:49 PM
