I need Del Sol vtec AC bracket.....
Can i just go to any honda dealership and get the del sol vtec AC bracket?? P54 right? Or would autozone or any other parts store have this??? its hot in TX i need my AC!!! thanks in advance
Just walk up to the parts guy and say you need 38930-P54-000 (94-95 Del Sol VTEC) or 38930-P30-000 (96-97 Del Sol VTEC/Civic Si) or 38930-P7J-000 (CRV)
sorry to thread jack...
but when you use the P54 bracket cause i already have it....can you use a single slammer compressor or is a dual cammer in need?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Just walk up to the parts guy and say you need 38930-P54-000 (94-95 Del Sol VTEC) or 38930-P30-000 (96-97 Del Sol VTEC/Civic Si) or 38930-P7J-000 (CRV)</TD></TR></TABLE>
wrong info, the P30 will not work for his set up! the P54 and the P7j are the only ones. if he gets the P30, the d-series compressor will not bolt up, and the b series compressor will not bolt to the d-series lines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
wrong info, the P30 will not work for his set up! the P54 and the P7j are the only ones. if he gets the P30, the d-series compressor will not bolt up, and the b series compressor will not bolt to the d-series lines.</TD></TR></TABLE>
thats exactly what i needed to know. thanks philosofy1
"This Honda AC compressor bracket is required when swapping in any B series motor into 92-00 Honda Civic. This bracket allows for the attachment of the original Civic AC compressor while upgrading the motor to a more powerful B series. With this there is no need to open the AC system and recharge at a later time. You must swap over the belt tension wheel and bolts included with your B series motor swap."
What exactly do they mean when they say,"You must swap over the belt tension wheel and bolts included with your B series motor swap"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATrin »</TD></TR><TR><TD CLASS="quote">
he means that the a/c bracket that came with the motor, you must take it out and swap it onto the new bracket, since the new bracket doesn't come with these things.
cheaper if u just call steve at hmotorsonline.com
thats where i got mine went from a d16z6 to a B18c so id call him a lot of cheaper
roc
Feb 29, 2004 06:01 AM
38930p30000, 38930p54000, 9495, 9697, ac, bracket, compressor, del, delsol, honda, mount, p30, sale, sol, vtec
