Information on 03 CBR 600 sprocket
Old Jul 21, 2006 | 09:27 AM
hinds90's Avatar
Default Information on 03 CBR 600 sprocket
I've been thinking about doing sprocket changes on my bike to get a little more accel around town. I don't stunt or track( although I may in the future) the bike, I may ride a little spirted at times but thats about as far as it goes. So what would be the best and least stressful set up to go with. Thanks for any reply's.
Old Jul 21, 2006 | 09:33 AM
buy my boosted ek's Avatar
Default Re: Information on 03 CBR 600 sprocket (hinds90)
-1 front
Old Jul 21, 2006 | 10:14 AM
marmaladedad's Avatar
+2 rear
Old Jul 21, 2006 | 12:13 PM
yimmy's Avatar
Default Re: (marmaladeboy)
You can go -1 down in the front whice is what I did because its cheap ($30). You can also go -1, +2 but then you have to get a new chain. You should also get a speedhealer to correct your speedo.
Old Jul 21, 2006 | 02:47 PM
JoshRambo's Avatar
Default Re: (yimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yimmy &raquo;</TD></TR><TR><TD CLASS="quote">You can go -1 down in the front whice is what I did because its cheap ($30). You can also go -1, +2 but then you have to get a new chain. You should also get a speedhealer to correct your speedo.</TD></TR></TABLE>
The stock chain will be fine with a -1, +2.
Although since you will be changing the sprockets you might as well get the chain as well.
If you would just do the -1 front you can get away with out getting a speedo healer. You would only be off a couple MPH's. If you do both you will need a speedo healer. you will be off by alot and your millage will not count right.
You can buy 520 Kits with chain and sprockets all over the place it is not that expensive at all.
Old Jul 21, 2006 | 08:51 PM
thehondaguru's Avatar
Default Re: (Gravity)
I went -1 +2 on mine and its a huge difference to me. I bought a speedo healer after the first ride though. It was WAAAYYY off.
I also had to take a link out of my chain when if came. Everyone told me that 110 links like the stock chain would do fine, but to get the chain adjustment right it was almost at the replace mark. So I tool out one link and it worked perfectly.
__oversea
Honda Motorcycles
16
Oct 3, 2008 09:25 PM
Jasper_db1
Honda Motorcycles
Nov 20, 2006 07:38 AM
eternity0114
Honda Motorcycles
Jul 21, 2004 08:45 PM
The G2 Racer
Honda Motorcycles
21
Jul 16, 2004 04:08 PM
9integra2
Honda Motorcycles
Jul 28, 2003 12:14 PM
