del sol ecu power problem
Old Jul 21, 2006 | 07:12 AM
bigdogadam's Avatar
Default del sol ecu power problem
ok so i've had some problems in the past iwth my del sol. i bought the car as a shell with no previous knowledge of its history. turns out it was a turbo car and had some weird wiring on the fuel pump. i since then have redone all of that and had the car running fine for over 3 monthes. yestarday i hit a pot hot and the whole car just died. i thought it was the fuel pump again but it wasn't. so ive tested the ecu with a test light and not a single pin is getting power. half of the fuse box in the car is dead aswell. no power windows, radio and some others are out. the fuse box under the hood checks out fine, everything has juice. i've replaced the main relay, checked all the grounds,switched ecus, went over every wire that i can see without pulling the dash. nothing works and almost nothing has power in the cabin. it's calling for 4 days of rain and my windows ae stuck down
help a brotha out
have any suggestions?
Old Jul 21, 2006 | 11:11 AM
bigdogadam's Avatar
Default Re: del sol ecu power problem (bigdogadam)
any suggestions greatly appreciated
judyn
Dec 21, 2017 11:50 AM
nselec3029
Jan 5, 2014 04:17 AM
srt4pilot
Mar 18, 2013 04:42 PM
sgnlab
May 28, 2012 08:26 PM
sivad84
Oct 29, 2011 06:02 PM
