FS - 2006 Bajaj Chetak - Annapolis, MD
MSRP $2899*
__________________________________________________ __
At 110 Miles per Gallon (per independent EPA City Cycle dyno tests) Bajaj scooters have the highest mileage rating of any 150cc scooter in the U.S. - Very Low Exhaust Emissions meet the strict California emissions standards - All Steel Monocoque Body, provides a rugged chassis with classic motor scooter style - Powerful, high torque, smooth running 4-stroke engine - 4-SPEED, all steel gears transmission for superior reliability - Built by Bajaj Auto Ltd., a modern manufacturer with over 40 years of experience building reliable scooters and utility vehicles - Compare features and see the Best Scooter Value in the U.S.
2006 Chetak Features
Rigid monocoque chassis made of high-strength alloy steel
Very low emission 4-stroke engine, 150cc, air cooled, 9 HP, overhead camshaft, oil pump circulation, oil filter, automatic variable advance electronic spark ignition
Electric and kick start
4 speed manual transmission, low friction all geared drive train for 100+ mpg
12 volt electrical system
Variable rate coil spring suspension with anti-dive front suspension, adjustable front/rear suspension to suit weight and road conditions
3.50 X 10 tires, 4 ply rating
Top speed 55 mph+
Curb wt. 253 lbs.
Max wt. 564 lbs.
Max recommended total weight rider & pass. 311 lbs.
Seat to ground dim.: 31"
Seat to deck dim.: 20.7"
Deck to grips dim.: 28"
Covered by a limited 2 year warranty
Top speed 55 mph+
Curb wt. 253 lbs.
Max wt. 564 lbs.
