WTF?? Every spark plug tube full of water!!!!!!!!!!! JDM B16A swap
Hey guys,
We'll, I have been working on my teg off and on,
So its been up on stands etc...
It hasnt been started for 1 month.
Its a JDM B16A swap from HMO,
So I just got done putting on a fender, gasket etc...
And see if the car will start, Well, I turn the key and Vroom, she started! first try after a month of sitting,
Its got a real rough idle, sounds like its missin in a cyl or two,
So I let it idle for a min thinking its just warmin up etc.... (I did an oilchange too)
Well I turn it off and start looking around, Make sure ecu getting power check fuses,
So I pull the spark plug wire and WATER!!!!!!!! WTF?? So I pull the next and its the same, each tube is full of water, So I run inside and begin typing this thread,
Well, I'm guessing that it built up while it was sitting for a month.
My question is, Am I screwed? Who do I get the water out?
I'm going to stick paper towls down there for now and see what I can do,
But how Do I get it all out?
thanks, Jose
Edit: Went bak out, its only # 1 and # 2 tubes that have water,
Do I need to change the plugs and wires once I get rid if the water?
thanks, Jose
ok thanks I used some paper towls and it got the water level to the tip of the plug,
Any other Ideas???? I'll be trying them all, this sucks
tried the wet vac, and it didnt really work, I might have gotten alittle but it didnt get it, But I'll go try some more.
soak as much up as possbile. then blow dry? thats the only thing i can think of. you want to make sure to get all of that out of there.
yeah thanks,
I took more paper towls and rolled them into little round peices
and stuck them down there with a long flat head,
I'll do the blow dry thing too, thanks guys for the help
I kinda freaked out there for a momment, I cant afford a new motor
Hell, I'm still paying for this one
hatchback_al
15
Jul 21, 2004 02:15 AM
wuhungsixxx
Jul 17, 2001 07:01 AM
