Replaced my front pads.. still feel no pressure?
Old Jul 20, 2006 | 09:48 PM
Tatakai's Avatar
Default Replaced my front pads.. still feel no pressure?
wtf? i think I might've gotten air in my lines but im not sure.
so i was replacing my front brakes, and it was being difficult so i decided losening the brake line banjo bolt would make things easier. i have no idea why i thought that idea made sense.. anyway, long story short, i lost some brake fluid in on one side (the bolt was loose) and i tried using that little bleader thingie to make it better and i tried all this crap..
anyways, can simply losening that stuff get air in the lines? and is there any easy way to get rid of it? i dont have easy access to a pump, and no money to buy one if needed
Old Jul 21, 2006 | 02:09 AM
jibs's Avatar
Default Re: Replaced my front pads.. still feel no pressure? (Tatakai)
You definately have air in your lines. If you don't have a mityvac pump with brake bleed kit, or can't afford the $30 for one, bleeding the brakes is a 2 man job. One in the car and one outside at the wheel. Pumping and holding the brakes while you open the bleeder. Then closing the bleeder before letting up on the brake pedal. I think the exact procedure is in your manual.
Old Jul 21, 2006 | 02:23 AM
thahuhstunna's Avatar
bleed the brakes--not a big deal, you should be back on the road very soon
Old Jul 21, 2006 | 03:15 AM
Tatakai's Avatar
Default Re: Replaced my front pads.. still feel no pressure? (thahuhstunna)
dope, i was hoping it was the same as when i had to bleed the clutch line on another car. thanks for the help.. now if only i can explain to my mom how to step on the brake like i need her too
dgdarien
Sep 15, 2009 04:23 PM
ch0baca
Jul 28, 2009 01:59 AM
tommyofyork
Apr 8, 2007 05:45 PM
Shiftandgo
May 20, 2006 07:47 PM
CobraCanuk
Nov 30, 2004 08:05 AM
