my car cranks but wont start! *searched* HELP!!
Old Jul 20, 2006 | 08:58 PM
y0whuddupb's Avatar
Default my car cranks but wont start! *searched* HELP!!
my car cranks but wont start! *searched* HELP!! « » 9:43 PM 7/20/2006 Reply Edit
ok here is the deal.
i have a H22A1 i was swapping into my prelude. before i went ahead and swapped the motor. i have done alot of removal modification. well balancer belt ripped on its own from the start. so i just left it off because its just waste of power. so thats off. i also removed my EGR system. i removed my EVAP canister. and i have removed my SRS system. so for the problem. the swap is nearly done. the motor is sitting and everything plugged up BUT the O2 sensor. it came down to starting it but for some weird reason it didnt want to start. gas was 1/4 full.
here are the things i have done to get this thing to start.
i checked all the lines. fuel lines and vacuum lines. i changed the main relay. fuel pump. map sensor. spark plugs. ignition coil. spark plug wires. cap and rotor. made sure it was at TDC before i started it. check all the fuses and relays which happens to be perfect. battery is brand spankin new. new terminals. i sprayed carb stuff into the manifold hoping it'll work. checked pressure on the fuel bolt which is on the fuel rail which was fine. the injectors are fine. though i am a tad bit skeptical about the fuel filter. i figured since fuel ran to the fuel rail it was running fine thru the fuel filter. i'll change that tomorrow but other than that i ran out of things to check and i really need help to figure out what the heck is wrong with it.
is there anything i might be forgetting to check? please help me! i want my car running already. thanks for any help!
rodriguez
May 26, 2008 10:59 PM
rodriguez
May 24, 2008 05:26 PM
y0whuddupb
Jul 24, 2006 08:10 AM
y0whuddupb
Jul 20, 2006 10:14 PM
.one lane
Oct 17, 2005 07:40 PM
