car wont rev past 6,000 rpm
Old Jul 20, 2006 | 08:47 PM
Slow_import's Avatar
Default car wont rev past 6,000 rpm
hi, i have a 90 civic si hatch, i slapped a z6 head, manifold and a aem adjustable cam gear on the stock a6 block, converted it to obd1 with the z6 dizzy, ecu, and jumper harness....i go to turn it on and everything is fine idles fine, but when i bring the rpms up, it wont rev past 6,000 rpm...car starts to loose power at 4500 rpm....feels like its hitting a rev limiter at 6000....tried ecu in another car and it goes fine up to 7000 rpm...no cel...any idea what it is....
Old Jul 21, 2006 | 03:58 AM
ludesrv's Avatar
Did you wire vtec? Cause your non-vtec cut is 6000rpm. And you wouldn't have power after 4800rpm cause you are suppose to be in vtec.
Old Jul 22, 2006 | 08:24 AM
Default Re: (ludesrv)
actually before the vtec conversion i could bring it up to about 7200....vtec and everything is wired up properly....no cel.....
severaltony
Mar 15, 2012 11:23 PM
Slow_import
Sep 23, 2006 11:48 PM
CRX MASE
Aug 4, 2005 06:20 AM
RACING INTEGRATION
Feb 5, 2005 01:42 PM
