B16 swap in progress
Old Jul 20, 2006 | 06:24 PM
crxpwr1's Avatar
Default B16 swap in progress
Im bored so I thought I would show every one what I plan on doing
Stuff need for B16 swap
~mounts
~ Shift linkage
~ integra axles
~ integra throttle cable
~ radiator and fan
~ piping for radiator
~ Rear motor mount bracket some swaps don’t come with it
~ wiring harness
~ brake up grade
~ change the spark plugs, alternator, and etc
~ header and piping and muffler
~ b16 complete change over
~ new tires
cost around 4000
i already have the b16 complete change over, radiator and fan, throttle cable, mounts shift linkage, wiring harness is on its way from rywire ,
I still need a little bit more and the only reason Im changing my brakes and tires is because when I bought the car it had shitty brakes and tires
Tell me what ya think and the B16 has a pr3 ecu and j1 tranny
Old Jul 20, 2006 | 07:34 PM
crxpwr1's Avatar
Default Re: B16 swap in progress (crxpwr1)
will have pics tomorrow of engine and I have plans to move the alt to where the power steering is so will let ya know how it goes
Old Jul 20, 2006 | 09:55 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxpwr1 &raquo;</TD></TR><TR><TD CLASS="quote">will have pics tomorrow of engine and I have plans to move the alt to where the power steering is so will let ya know how it goes</TD></TR></TABLE>
Curious, why ?
Old Jul 21, 2006 | 05:50 AM
crxpwr1's Avatar
Default Re: B16 swap in progress (90blackcrx)
why dent in your engine bay if you can just move it and if you ever had to replace the alt it would be a bitch because It would be all close to the bay so why not just move it
Old Jul 21, 2006 | 05:56 AM
Loserkidwac's Avatar
The dent isn't even that noticable, you will need to fabricate both mounts and find a belt to fit, I mean it can be done but I replaced my alternator and had enough room to pull it up through and out the top next to my intake mani, you will also need to exend the wire harness too
Old Jul 21, 2006 | 06:13 AM
crxpwr1's Avatar
Default Re: B16 swap in progress (Loserkidwac)
we was gonna try and do it and if we had to fabricate the mounts we werent going to move it so I dont know extend wires is easy its just lining the alt. up and getting a belt
Old Jul 21, 2006 | 06:19 AM
I'm not an electrician but I don't know if you exten the wires to much and make them to long that will decrease the amperage or voltage or something I believe, I mean go for it, it would be cool, but seems like a lot of work...I can show you how to fit a D series alt on you B series
Oh yea when I replaced mine all I did was unbolt it, remove the top alt mount and just pulled it right up, wasn't to hard but I have a B18b with an OBD1 intake mani in my crx, don't know if a B16 wouldbe different
Old Jul 21, 2006 | 01:52 PM
crxpwr1's Avatar
trying to save money really dont need to buy a d sereis alt. but I really didnt get to work on it today had to help a buddy move but I did look into switching it and you would need custom brackets because were off by half a bolt. Probably going to leave alt where its at and see if it fits with out banging in the wall
Old Jul 21, 2006 | 02:44 PM
Oh no I wasn't saying to buy a D series alt was just saying that it can be done so maybe mounting on the front would work, but yea it looks to be a pain...
I would suggest you bang out the frame because once you get the motor in and realize just how close it is if it isn't hitting the frame you will have to pull the motor out to dent it in, just do it, its been done many tiems and there is a reason you should do it, I believe it fits but when you try to adjust the belt you'll hit the frame, and if your mounts aren't stiff the engine could tourqe and send the alt into the frame probably causing a big mess
Old Jul 21, 2006 | 03:51 PM
crxpwr1's Avatar
thanks man thats nice to know and I took my shift linkage out today and will but the b series linkage in tomorrow.......really easy to take out linkage never knew it was that easy...lol
Old Jul 21, 2006 | 04:01 PM
Yea linkage can be easy its just the pin that is a pain, I left mine attached when I dropped the D out, it was really easy to get out once the motor was on the ground
Old Jul 21, 2006 | 04:07 PM
crxpwr1's Avatar
what pin I didnt see no pin? The part that goes into motor becuase that part was just hanging but where is the pin located I might have lost it
Old Jul 21, 2006 | 04:13 PM
The pin in the end of the linkage that attaches it to the tranny
Old Jul 21, 2006 | 04:22 PM
ef9robert's Avatar
How do you take the pin out?
Old Jul 21, 2006 | 04:48 PM
Default Re: (teamsonik)
I believe its an 8mm punch and just tap it out with a hammer but it is a Bitch hence the name "Bitch Pin" some people use air hammer/chisles with a punch thats the easiest if you have air tools and I know a guy on here made tool out of a C clamp that wil remove it
Old Jul 21, 2006 | 04:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxpwr1 &raquo;</TD></TR><TR><TD CLASS="quote">we was gonna try and do it and if we had to fabricate the mounts we werent going to move it so I dont know extend wires is easy its just lining the alt. up and getting a belt</TD></TR></TABLE>
You won't notice a dent if you do it right, put tape over the area first even then its down below.
Second there is no room up front for the alternator.
Old Jul 21, 2006 | 04:52 PM
crxpwr1's Avatar
yea we went and took a look were just going to dent in will have pictures of this process and every thing i have for the swap in a couple days really busy this weekend
Old Jul 21, 2006 | 05:59 PM
crxpwr1's Avatar
I went out an double checked I didnt have a pin where can I get one? lowes or home depot?
Old Jul 21, 2006 | 06:14 PM
ef9robert's Avatar
okay so i jack up the rear and the front on jack stands slide under and punch it out with a air gun punch?
Old Jul 21, 2006 | 06:18 PM
crxpwr1's Avatar
I have my shift linkage already taken out.......what are you talking about?^^^^^^^^^
Old Jul 21, 2006 | 06:34 PM
G0crxG0's Avatar
If you don't want to damage your engine bay when bangin it out for the alternator, go get a bath towel, fold it up thick, and put it against the bay b4 you start banging. That way you wont put any gashes or scratches in.
Old Jul 22, 2006 | 08:52 AM
Default Re: B16 swap in progress (G0crxG0)
If you need one I would suggest ordering one from honda, it is somewhat speciallized for the application, I have heard of people just using a bolt but that my cause slop
Old Jul 22, 2006 | 11:06 AM
Suck my DX's Avatar
u could have used your stock throttle cable if you modified the bracket like i told you...<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxpwr1 &raquo;</TD></TR><TR><TD CLASS="quote">I went out an double checked I didnt have a pin where can I get one? lowes or home depot?</TD></TR></TABLE>
has the car been sitting for a while...i cant see how you can drive without the pin in the linkage
Old Jul 22, 2006 | 02:55 PM
crxpwr1's Avatar
Default Re: B16 swap in progress (Suck my DX)
yea i bought it with no engine so I guess its been sitting for a while its a project car
Old Jul 22, 2006 | 02:57 PM
crxpwr1's Avatar
does any one know the part number for the pin? and do you think it will be expensive
