Anyone know whether the R can run 15x7.5 SSR comps + 225 tires with no rubbing?
You know... that's the $64,000 question!
I'll see where the 205's sit in a few days or so, and give a full report.
I ran 225's on my stock 6's with stock suspension, and they did pretty well..
front would rub when turning on a driveway
The rear did fine until I got a flat....... didn't know it.......turned.........rubbed on lower control arm...........got sideways.........
For what reason are you running 225's........ If you want to do it for traction purposes, it won't help.....
225 without a spacer will run and with a spacer if you are lowered it will rub the fender instaed of the sustemsion.
225 without a spacer will run and with a spacer if you are lowered it will rub the fender instaed of the suspension....
Just checking to make sure we're not talking about the stock 6" rim any more. Ed
I think the 225 will rub no matter what wheel you put it on. 6'' - 7'' - 7.5''
I have 15x7'' wheels with a 43mm offset. Im using the knew V700's 225-45-15. My car is lower than stock, and it rubs in the rear WITh the 5mm spacer. It is not rubbing the control arm, but the fender. I will raise the car to fix this.
The fronts seem to be Ok, even with the lowered. I will post a few pics, asap.
Bryan
Bryan
I have actually seen stock wheels with 225 with the same issues. It is more so the 225 width than the 7.5" wheel. The widest I would ever consider for an integra is a 7"/ Just personal preference but a 225 is going to be work.
Bryan
Bryan
So would I be ok at the height you are (how low are you, btw?) with 15x7 and 205's?
You should have NO problems with 205 tires on a 7" wheel...
Ok, then what offset is best? I mean to go as low as possible.....
Tommy_Gunns
Sep 11, 2002 09:49 AM
Rembrant Q. Einstein
May 15, 2002 05:44 AM
