Need help fixing 88 Integra
Old Jul 20, 2006 | 05:48 PM
klpts's Avatar
Default Need help fixing 88 Integra
I am new to this forum and am not sure where to find any info/links/DIY's/retailers for acura parts. I took my car in for brake service as the rears were shot. It came up with also that the fronts are rusted and shot.
So I need rotors, calipers, pads, and everything else associated with changing the front brakes.
Where can I find info on changing these and whats the best stuff to replace everything with cost in mind.
The other issue is that it was recomeneded for timing belt replacement with seals and water pump.
What are the seals that I need to purchase, and any DIY's and links to products regarding fixing these issues.
Any input will be greatly appreciated.
-Kyle
Old Jul 21, 2006 | 01:24 PM
jared99's Avatar
Default Re: Need help fixing 88 Integra (klpts)
Brakes:
http://www.team-integra.net/se...D=373
Bleeding the brakes--This is optional depending on how you change the pads..I never have to do this, but here's the info.
http://www.team-integra.net/se...D=417
Timing Belt/Water Pump
http://www.team-integra.net/se...=1044
It's more difficult to find stuff for the 88 Integra, these are for the 94-01 models. Some things might be different but the timing belt part should be pretty close to the same.
donuttes
Jul 5, 2006 02:02 PM
TEGGRY
Mar 10, 2006 02:16 PM
Stealthman80
Sep 7, 2005 08:50 PM
HatchBox
Dec 9, 2004 03:54 AM
93SSPHatch
May 15, 2002 05:17 AM
