HELP!!! my zc soch is blown and i need to see........
Old Jul 20, 2006 | 04:00 PM
elecgenius's Avatar
Default HELP!!! my zc soch is blown and i need to see........
i need to see if i rebuild a d16a6 motor i got laying around and use my ZC's pistons (cus i guess theyre high comp instead of the stock d16a6's) would it be the right dimensions and stuff. can i use the sc pistons with a d16a6 motor and a zc head, or what type of scramble would be best.
thank you in advance
p.s. i have to put the d16a6 cus it just got refereed and my motor blew a week later {i blew it on purpose cus i was pissed of,,,no oil..hehe) i have to put a d16a6 so i can be all legal but im gona do machine shop work on it like polishing, porting (i dont know what else to do to the internals other then that) so.....yeah}
Old Jul 20, 2006 | 04:07 PM
Tyson's Avatar
Default Re: HELP!!! my zc soch is blown and i need to see........ (elecgenius)
the bottom end of the sohc zc (non vtec) is the same as the d16a6. the pistons are the same. the DOHC ZC pistons are higher compression, not SOHC.
you can use all the parts.
Old Jul 20, 2006 | 04:28 PM
elecgenius's Avatar
Default Re: HELP!!! my zc soch is blown and i need to see........ (Tyson)
oops, then if i get high compression pistons on the soch, would it make a difference on the power cus my uncle has a machine shop and hes gonna do that and im just gonna install it myself
Old Jul 20, 2006 | 07:57 PM
y-49's Avatar
hell yeah it will make a diference in power. and i am pretty sure that the zc pistons are higher comp than the si's. but someone corect me if im wrong
Old Jul 20, 2006 | 07:59 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">the bottom end of the sohc zc (non vtec) is the same as the d16a6. the pistons are the same. the DOHC ZC pistons are higher compression, not SOHC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow rex &raquo;</TD></TR><TR><TD CLASS="quote">hell yeah it will make a diference in power. and i am pretty sure that the zc pistons are higher comp than the si's. but someone corect me if im wrong</TD></TR></TABLE>
im curious. did you not read what i said? or do you just not believe me?
Old Jul 20, 2006 | 08:03 PM
Tippyman's Avatar
or do you just not believe me? </TD></TR></TABLE>
Oh, ye of little faith!
Old Jul 20, 2006 | 08:08 PM
C_R_X_V_T_E_C's Avatar
QUESTION? WHY WOULD YOU BLOW UP YOU'RE ENGINE IN THE FIRST PLACE, THATS PART OF THE REASON WHY YOU HAVE THIS DILEMMA, IS CUZ STUPIDITY OVERRODE ANY COMMON SENSE YOU MIGHT HAVE HAD, NO OIL???? IF YOU'RE ALREADY DOING A SWAP YOU COULD HAVE JUST YANKED THE EXISTING MOTOR AND SOLD IT AND MADE YOURSELF SOME MONEY AND GOT THE PORT AND POLISH................, BUT FOR LACK OF A BETTER WORD, THATS RETARDED.
Old Jul 20, 2006 | 08:21 PM
y-49's Avatar
naw i believe u but i also heard that the zc pistons in a a6 block were like 10.2:1 comp ratio
Old Jul 20, 2006 | 09:43 PM
elecgenius's Avatar
Default Re: (yellow rex)
i think you guys got it all wrong,, i blew the engine cus i got pissed off and didnt give a f##k no more. i have spent over 20000 in tickets and impounds in the las 2 yrs. i did some time already, and believe it or not, for fix it tickets,,,,well cus my student visa expired and i cant leave the country but cant get my residency cus im in the process,,, so everytime i geet pulled over (i.e.,,one lug nut missing on my rear tire) i get screwes with no vaseline. i got sick of it and let is go on purpose. and 250 for another engine aint s#it, i can get that in less then a days work. but yeah,, got my engine saved just need to pick it up tommorrow (d16a6) andi still need help. d16a6 w/ dohc zc pistons?? cus those are high comp but no one ever clarified if they are compatible (im worried about clearence with the doch zc head). the d16a6 im getting is running so if the power gain is too little, ill just leave the engine as is till i get my h22 in that puppy. or i can do it and then sell it to oe of you fine folks for more cus its modded ...hehe
Old Jul 20, 2006 | 09:50 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow rex &raquo;</TD></TR><TR><TD CLASS="quote">naw i believe u but i also heard that the zc pistons in a a6 block were like 10.2:1 comp ratio</TD></TR></TABLE>
you do understand there is a sohc zc and a dohc zc, right? it doesnt seem like it...
elecgenius, just throw the d16a6 in there and stay legal.
Old Jul 20, 2006 | 09:58 PM
nelsmar's Avatar
just to note, i dont think the DOHC ZC head fits on a a6 block
Old Jul 20, 2006 | 09:59 PM
Tyson's Avatar
Default Re: (nelsmar)
it sure doesnt.
who said that it did?
just to note, H series trannies dont fit ZC's either.
Old Jul 20, 2006 | 10:15 PM
nelsmar's Avatar
he was talking about puting the DOHC on the SOHC motor(from what i quickly read) no one said anythign so i just wanted to make sure its known : P
Old Jul 20, 2006 | 10:17 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nelsmar &raquo;</TD></TR><TR><TD CLASS="quote">he was talking about puting the DOHC on the SOHC motor(from what i quickly read) no one said anythign so i just wanted to make sure its known : P</TD></TR></TABLE>
no he didnt.
it was about using DOHC pistons were worth it or not. not the head.
Old Jul 21, 2006 | 08:13 AM
elecgenius's Avatar
Default Re: (Tyson)
no he didnt.
it was about using DOHC pistons were worth it or not. not the head.</TD></TR></TABLE>
right on
Old Jul 21, 2006 | 08:21 AM
RexShop's Avatar
This thread is dumb.
F- for blowing up your motor on purpose.
Old Jul 21, 2006 | 08:54 AM
SIred91's Avatar
Rainman
Default Re: (RexShop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RexShop &raquo;</TD></TR><TR><TD CLASS="quote">This thread is dumb.
F- for blowing up your motor on purpose.</TD></TR></TABLE>
F- for being an asshat in any thread the OP has posted in. Like I said before.
ELECGENIUS IS A ******* MORON AND SHOULD BE BANNED!
Go back to wherever it was you came from and "have another tequila!"
Old Jul 21, 2006 | 09:04 AM
Tyson's Avatar
Default Re: (SIred91)
wtf is the drama?
Old Jul 21, 2006 | 09:10 AM
SIred91's Avatar
Rainman
Default Re: (Tyson)
^^ go check out "Where Did You Get Your ZC Swaps?"
That will show you what a shart this dude is.
Old Jul 21, 2006 | 09:14 AM
Tyson's Avatar
wtf does that have to do with this thread?
Old Jul 21, 2006 | 09:16 AM
SIred91's Avatar
Rainman
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">wtf does that have to do with this thread?</TD></TR></TABLE>
Absolutely nothing, I'm just shitting out my mouth and being an *** to this guy.
Honest enough?
Old Jul 21, 2006 | 09:19 AM
Tyson's Avatar
all technical questions have been answered in this thread.
/thread.
/drama.
grow up.
Old Jul 21, 2006 | 01:05 PM
nelsmar's Avatar
Default Re: (elecgenius)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elecgenius &raquo;</TD></TR><TR><TD CLASS="quote">got my engine saved just need to pick it up tommorrow (d16a6) andi still need help. d16a6 w/ dohc zc pistons?? cus those are high comp but no one ever clarified if they are compatible (im worried about clearence with the doch zc head). the d16a6 im getting is running so if the power gain is too little,</TD></TR></TABLE>
he said right there.... clearence with the DOHC ... head
Old Jul 22, 2006 | 10:42 AM
elecgenius's Avatar
you sould be banned moron!!!! hijacking threads to talk s#it. is it a dumb *** question to ask if the clearence from the doch zc pistons is safe enough to install them on an a6 moto without f'n it up.....leave my thread
Old Jul 22, 2006 | 11:10 AM
elecgenius's Avatar
i appreciate all your guys input (even that one moron) but thank you, i got my d16a6 and i just repackaged the engines gaskets and got the cleanest looking engine ever. im ready to take out the other (just take off axles and unbolt motor mounts. it should be done by sunday. thank you for all your help once again and im just gonna unreferee it and later on stick an h22 i got laying around my house
