power assisit on brakes has failed, why? brakes peddle hard to push
Old Jul 20, 2006 | 01:42 PM
atvhigh's Avatar
Default power assisit on brakes has failed, why? brakes peddle hard to push
brakes still work on car. must push extremly hard on pedal to stop. Master cylindar is full to Maximum line. when you push on peddle, RPM's pick up, let off on peddle RPM's drop back. Peddle travel is very short before going rock hard.
Whats up? is there an electrical sensor out?
Old Jul 20, 2006 | 01:52 PM
postman's Avatar
Default Re: power assisit on brakes has failed, why? brakes peddle hard to push (atvhigh)
brake booster
Old Jul 20, 2006 | 02:07 PM
atvhigh's Avatar
Default Re: power assisit on brakes has failed, why? brakes peddle hard to push (postman)
can it be the sensor in the vacum line, gone bad, sticking, or replace the booster?
Old Jul 20, 2006 | 08:46 PM
jdeemseerx's Avatar
open your hood and look at the vacuum line coming off of the booster, take the check valve off (the plastic piece in between the 2 lines) and blow into it it should only blow through one way, if it doesnt blow through at all the valve has gone bad.
i havent heard of too many boosters going bad but it is a very good possibility
tim_r95
Mar 10, 2015 07:50 AM
rizzuto_usmc
Oct 28, 2013 04:55 AM
JDMRice
Sep 3, 2006 06:06 AM
zcpowereddx
Jul 4, 2002 10:35 PM
