Idle Low - Electrical Load Causes 700rpm Difference. What Causes?
Old Jul 20, 2006 | 12:07 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default Idle Low - Electrical Load Causes 700rpm Difference. What Causes?
The car is an 88 crx si with a d16a6
The car when warm will idle at about 900-1000rpm, but when I need to turn on the headlights (sidemarkers also tap into headlights circuit) the idle will drop to 400 and the engine wants to die
I also have a power wire coming straight off the battery to a switch and then to multiple assecories in the car (4 gauges, wideband, shiftlight)
When this is turned on it will also lower the idle a good 150 or so rpm
The headlights are Ebay projectors but I never had this problem last year. Why would the car idle so dam low and why would the load make such a difference?
I did just put in a new battery
Old Jul 20, 2006 | 12:30 PM
ludesrv's Avatar
The draw is so much it's killing your car.
Your alternator must REALLY suck.
Old Jul 20, 2006 | 01:03 PM
PINKS's Avatar
Default Re: (ludesrv)
Alt puts out 14.5volts
Old Jul 20, 2006 | 01:10 PM
efyou's Avatar
Default Re: (PINKS)
bad grounds?
Old Jul 20, 2006 | 03:42 PM
PINKS's Avatar
Default Re: (efyou)
Alt is fairly new from a junkyard, pushes 14.5V all day
I lied though, the rpm drops almost 400 with the accesory switch on
I know my valve cover ground isnt perfect as I painted my valve cover and didnt sand it, but it is upgraded to 4gauge as is my battery ground wire which is a clean ground to the tanny and I have 2 extra from the battery to the headlight housing
Old Jul 20, 2006 | 08:01 PM
efyou's Avatar
Default Re: (PINKS)
what amps is the alternator spec'd for?
Old Jul 21, 2006 | 11:56 AM
PINKS's Avatar
Default Re: (efyou)
Its the stock d15b alternator, I dont know
Old Jul 21, 2006 | 12:01 PM
ludesrv's Avatar
Default Re: (PINKS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS &raquo;</TD></TR><TR><TD CLASS="quote">Its the stock d15b alternator, I dont know</TD></TR></TABLE>
Isn't that like...90AMP?
Old Jul 21, 2006 | 05:05 PM
PINKS's Avatar
I believe so
So is the stock crx though
the headlights serioulsy cause a 500 rpm drop
Old Jul 21, 2006 | 08:21 PM
PINKS's Avatar
Default Re: Idle Low - Electrical Load Causes 700rpm Difference. What Causes? (PINKS)
why would an alternator cause a 500rpm drop in idle?
Anyone heard of an electrical load detector?
where is it?
Old Jul 21, 2006 | 09:03 PM
Jonathan_ED3's Avatar
I feel your pain man.
Some of my EF's have this problem. Some do not. The only thing I can think of doing is replacing all the major grounds and going from there.
It's so bad that my blower motor will barely blow if I'm idling. If I rev it up, it blows nice and hard. The alternator just doesn't pump out enough at a lower idle. Maybe I should look at an upgraded unit.
Old Jul 21, 2006 | 09:55 PM
PINKS's Avatar
Default Re: Idle Low - Electrical Load Causes 700rpm Difference. What Causes? (Jonathan_ED3)
Hey, I actually noticed that today, my blower motor would kind of surge, its an accord climate control though I figured I just wired it wrong.
My alt is just going bad?
I guess I should clean up the grounds
Old Jul 22, 2006 | 08:26 AM
PINKS's Avatar
Old Jul 22, 2006 | 01:12 PM
PINKS's Avatar
Old Jul 23, 2006 | 06:10 AM
PINKS's Avatar
for low idle
Old Jul 23, 2006 | 10:26 AM
PINKS's Avatar
bump bump
Old Jul 23, 2006 | 06:08 PM
PINKS's Avatar
Old Jul 24, 2006 | 02:44 AM
PINKS's Avatar
bumpity bump
Old Jul 25, 2006 | 03:48 PM
PINKS's Avatar
simplsi
Nov 7, 2006 08:28 AM
ludedude808
Nov 5, 2006 10:44 PM
simplsi
Oct 26, 2006 12:25 PM
PINKS
19
Jul 25, 2006 03:47 PM
96RS
Mar 18, 2003 11:46 AM
