Where Did You Get Your ZC Swaps
http://www.hmotoronline.com
You know what, normally I post a whole list, but no, not anymore. Why bother? You guys never learn. You have been here since 03 and you don't know how to search? Come on man...
I wanted up to date answers, not archived **** from 03. Get over it, how long did it actually take you to type that response..
Thanks for the replies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voodooboy520 »</TD></TR><TR><TD CLASS="quote">Well, they both have the same power.
But with a SOHC, you have to get a VTEC ECU and wiring harness. DOHC drops right in with current wiring, plus the valve cover looks cooler
Right and that I understand. There is limited performance with those motors since there is no aftermarket. That is all, that and I have seen 3 DD DOHC ZC's take a crap all in the bottom end. Everyone must do what they want thought too.
</TD></TR></TABLE>Right and that I understand. There is limited performance with those motors since there is no aftermarket. That is all, that and I have seen 3 DD DOHC ZC's take a crap all in the bottom end. Everyone must do what they want thought too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doh! »</TD></TR><TR><TD CLASS="quote">I wanted up to date answers, not archived **** from 03. Get over it, how long did it actually take you to type that response..
Thanks for the replies</TD></TR></TABLE>
Same suppiers since 03.
Thanks for the replies</TD></TR></TABLE>Same suppiers since 03.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">
Right and that I understand. There is limited performance with those motors since there is no aftermarket. That is all, that and I have seen 3 DD DOHC ZC's take a crap all in the bottom end. Everyone must do what they want thought too. </TD></TR></TABLE>
The aftermarket is there, its just harder to find. Cams are pretty easy to find, and thats all you really need. Other stuff (Cam gears, etc) are pretty hard to find, but who needs them really? Its still a D series, so keep in mind they wernt designed to make tons of power. Any minor bolt on that fits an a6 will fit the ZC (with the exception of headers - you have to slightly portmatch those). If your looking for tons of power, just go B series. If you want an engine that runs on midgrade and still gets 35MPG city, go with the DOHC ZC. Its a nice daily driver engine, and they seem to love boost.
And I think they spin bearings on the bottom end is because people rev them to 7200 RPM +.
Not trying to flame, just debating
you do realize that the DOHC ZC bottom end is <U>exactly</U> the same as all SOHC D16 engines (other than having higher compression domed pistons)? that being the case, why would they be any more likely to have problems than a SOHC? also, a SOHC VTEC ZC (or D15B or D16Z6 or D16Y8) will not perform as well as the DOHC ZC - not even close
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">
you do realize that the DOHC ZC bottom end is <U>exactly</U> the same as all SOHC D16 engines (other than having higher compression domed pistons)? that being the case, why would they be any more likely to have problems than a SOHC? also, a SOHC VTEC ZC (or D15B or D16Z6 or D16Y8) will not perform as well as the DOHC ZC - not even close</TD></TR></TABLE>
why do they have more problems you ask? because dumbasses who think they are getting an upgrade rev the **** out of them and then wonder why they take a dump!
you usually know your ****, but why do you say no other D will perform as well?
did you smoke some crack this morning? "not even close" you say?
Please think a little before spreading crap like that around. its a great engine, just like most all other Honda engines, but a sight more pickish to find parts for, and the bolt-on aftermarket will put a Z6 well beyond the potential of a DOHC ZC.
haha,,funny, the guy just asked where to get one from,,,,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doh! »</TD></TR><TR><TD CLASS="quote">Where did you get your ZC swap, and where would you recommend I do so </TD></TR></TABLE>
hmotors is great,, or nippon-motors.com,,or ebay seller with good rating...
also i see you're in NY? theres a place over here in paterson nj that sells jap engines jdmenginedepot.com they got the obd0 88-91 dohc zc and obd1 92-95 dohc zc in stock
Well anyways, Hmotors is great. I got mine 700 shipped.
What kind of bolt on aftermarket are we talking about? The DOHC makes 130 HP WITHOUT VTEC, which means that either the cams are more agressive or the head flows better. Normal bolt ons have nothing to do with the potential of a motor. That has to do with the rod\stroke (or something like that..) ratio, and how well the head flows. Plus, you can adjust each cam individually, ADDING to the "potential" of the motor.
Even if the heads flow the same, and the blocks are the same, the DOHC will always have the advantage because of the adjustability.
ihave ran the **** out of my dual cam zc and never had prob. yet out of bottom end.neglect to change oil over time would do that.it really dont matter what u have if u beat on it and not keep care of it any motor will take a **** on u.
btw i got my from gomotors 750 shipped just engine and pm7 ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> dont blame the engine, blame the dum asses. i had soch zs, dohc zc and soch vtec,,nothing ran like the soch zc. the other is kinda heavy and the soch vtec kiks but after teh vtec does,,,,by then the guy with the soch zc is gone....ehe
p.s. btw i was that dumass and went through 3 engines already. oops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elecgenius »</TD></TR><TR><TD CLASS="quote"> dont blame the engine, blame the dum asses. i had soch zs, dohc zc and soch vtec,,nothing ran like the soch zc. the other is kinda heavy and the soch vtec kiks but after teh vtec does,,,,by then the guy with the soch zc is gone....ehe
yah, I was calling the ppl dumbasses, not the motor.
and for the first half of your post....do u spreekah dee ingrish?
anyway, I have played with all 3 ZC's and my favorite would have to be the no-tec single slammer. Just my opinion though.
</TD></TR></TABLE>yah, I was calling the ppl dumbasses, not the motor.
Another moron trying to rely on his 'Master's Degree' on education. Either that is his plan or he is trying to change the world to feel fulfilled in his misery.
comm'n man, ill fucken school ur *** in proper english. ur talking to someon with a 137 IQ, i know its no the highest but ***, i came here to talk 'engine', not english. school was over in my teens, why the hell would i wanna go back after putting all that time in to it. and plus you moron, if you wouldve had enough thinking capacity, you would have realized that you where basically stating that those engines suck. 'why do they have more problems you ask? ' well, your right, but your context makes it come across as if thay suck cus theyre blown a lot. its cus of idiots trying to rev it and in no way does it decrease the integrity of the DOHC ZC
There is limited performance with those motors since there is no aftermarket. </TD></TR></TABLE>
People say that all the time, but I'd like for someone to name some parts that are available for the SOHC that are not avalable for the DOHC ZC. There may not be the variety (which half the variety is either a knock off or garbage) but the parts are there. Not garbage parts, but proven parts used over and over.
stock for stock and mod for mod I would agree
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elecgenius »</TD></TR><TR><TD CLASS="quote"> school was over in my teens, ... </TD></TR></TABLE>
your only 20...you just said that as though your teens were years ago.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elecgenius »</TD></TR><TR><TD CLASS="quote">Another moron trying to rely on his 'Master's Degree' on education. Either that is his plan or he is trying to change the world to feel fulfilled in his misery.
ROFL read your posts and then your claims.
LOLOLOL.
Best line ever on HT :<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elecgenius »</TD></TR><TR><TD CLASS="quote">comm'n man, ill fucken school ur *** in proper english. ur talking to someon with a 137 IQ,</TD></TR></TABLE>
I think you are missing a . in that #.
</TD></TR></TABLE>ROFL read your posts and then your claims.
LOLOLOL.
no the best line '*** off'
just playing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elecgenius »</TD></TR><TR><TD CLASS="quote">Another moron trying to rely on his 'Master's Degree' on education. Either that is his plan or he is trying to change the world to feel fulfilled in his misery.</TD></TR></TABLE> we all came here to speak 'engine.' thats the bottom line.
just playing<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elecgenius »</TD></TR><TR><TD CLASS="quote">Another moron trying to rely on his 'Master's Degree' on education. Either that is his plan or he is trying to change the world to feel fulfilled in his misery.</TD></TR></TABLE> we all came here to speak 'engine.' thats the bottom line.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elecgenius »</TD></TR><TR><TD CLASS="quote">no the best line '*** off'
just playing
[QUOTE=ME] Another moron trying to rely on his 'Master's Degree' on education. Either that is his plan or he is trying to change the world to feel fulfilled in his misery.
QUOTE] we all came here to speak 'engine.' thats the bottom line.
Wow.
just playing[QUOTE=ME] Another moron trying to rely on his 'Master's Degree' on education. Either that is his plan or he is trying to change the world to feel fulfilled in his misery.
</TD></TR></TABLE>Wow.
WoW! did you try to read this before you posted it? but I guess it's that 137 IQ
</TD></TR></TABLE>WoW! did you try to read this before you posted it? but I guess it's that 137 IQ
