Are 88 and 90 master cylinders the same? CRX SI's?
Old Jul 20, 2006 | 10:06 AM
1990hondaHF's Avatar
Default Are 88 and 90 master cylinders the same? CRX SI's?
both are fron CRX SI's.....brake master cylinders? Will the 88 SI work on a 90 SI? Thanks.
Old Jul 20, 2006 | 11:52 AM
MrPotatoeHead's Avatar
Default Re: Are 88 and 90 master cylinders the same? CRX SI's? (1990hondaHF)
They all fit, but if you go 90 lx sedan I believe its the same size as a Da.
Correct me if im wrong
Old Jul 20, 2006 | 11:58 AM
CRX Toad's Avatar
Default Re: Are 88 and 90 master cylinders the same? CRX SI's? (MrPotatoeHead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrPotatoeHead &raquo;</TD></TR><TR><TD CLASS="quote">They all fit, but if you go 90 lx sedan I believe its the same size as a Da.
Correct me if im wrong </TD></TR></TABLE>
Yes you are wrong....very close but wrong. You want the 90-91 Civic 4dr EX it is larger and bolts right up. You stock one is 13/16 the EX one is 15/16.
Old Jul 20, 2006 | 01:18 PM
Default Re: Are 88 and 90 master cylinders the same? CRX SI's? (CRX Toad)
I was told Lx so its an ex...oops
Old Jul 20, 2006 | 03:56 PM
Tyson's Avatar
88 Si is the same as DX 13/16".
90 Si is 7/8".
it will bolt up. but the brake pedal travel will be longer.
Old Jul 20, 2006 | 09:40 PM
Default Re: Are 88 and 90 master cylinders the same? CRX SI's? (Tyson)
thank for the in guys. I never knew different years had different pedal travel....
Old Jul 20, 2006 | 09:52 PM
Tyson's Avatar
no, it just changes because of the different bore size doesnt match the piston size. 90-91 Si have large calipers and rear disc brakes.
but changing just the MC to a smaller bore size will take more pedal stroke for the same amount of volume. 7th grade math.
Old Jul 21, 2006 | 10:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote"> ...7th grade math.</TD></TR></TABLE>
well thanks goD I be have my GED.
1990hondaHF
Aug 10, 2006 12:13 PM
Drag4Life723
Apr 12, 2004 10:39 PM
sircrxracer
Jan 2, 2004 03:03 PM
Count Blah
Oct 15, 2002 11:20 AM
