building an ls wondering what oem pistons fit
ok guys im building an ls turbo but dont wanna use an aftermarket piston because of how cheap i can get oem acura/honda parts. So im wondering what pistons, besides ls fit on ls rods and will work in an ls motor thanks guys
for turbo you want to stick with the stock LS piston but you are limtied to how much power you can put down through stock components though.
It's really not the pistons and rods that are the immediate weakness.
If you are shooting for HP goals of 280 or higher, the stock sleeves are going to give before the piston/rods do, if the engine is tuned properly.
true however i believe if you are looking to build up a motor and use oem pistons you probably arent going to be using aem ems. melting pistons,snaping rods ect... why not just og with the good stuff while building it now? instead of doing it later.... plus sleeved blocks are out there and not that much money its definitly worth saving to have a legit build and legit block
I totally agree. If I were rebuilding an engine and my plans were to achieve high horsepower, stock internals would not be on my list.
I just wanted to point out that the OE stuff is good up to a certain HP level.
ohhh most def but gentleman this is everyday kinda car if i had 200hp/150tq at the flywheel its better than the 70hp/90tq of my d15. so i have these parts laying around ls long block, 2000 b16a2 head (complete), and just want somthing i can run up to the pump with pour 93 in and just be able to do low 14's maybe high 13's then i can work on looks and sus. . .
what you think guys???
just build a stock ls vtec and you should see 13s no problem.. The stock setup is good as your tuner is. IF your tuner knows what he is doing then you will make some decent power on a stock block
well when i called up the acura dealship and got a price on oversized itr pistons, wrist pins, and rings it was like under 300 with my commercial account so thats why im thinking of going that way
any thoughts now???
oh p.s. first honda engine build and no experience with ls/vtec so thats why im acting like a noob with this ****. Fixing mom's minivans and whatever else rolls into my shop with facctory replacement parts im good but this hybrid **** is getting me!!
any thoughts now???
Nonvtak monster
Oct 31, 2013 09:13 AM
queda
12
Nov 1, 2007 10:05 PM
