cheap fix for my trim peice?
Old Jul 20, 2006 | 04:59 AM
wcsh86's Avatar
From: Mississippi (awful place, do not come to visit)
Default cheap fix for my trim peice?
Ok, first off. This picture is NOT my car. My car is the dark red of the 94 accords. Kinda Maroon. (sorry if this is your car and it was a jackass move to use your pic) I just google imaged accord to find the picture because I'm not sure exactly what this peice is called. Well I bought the car with this peice missing. It has the holes going back all the way. I found some unpainted ones.. Do you think I could just get the unpainted one and paint it that color? what's the cheapest way to fix it. I never thought it would have bothered me, but it's really starting to get to me. Thanks guys.
EDIT: My pic didn't work, so i picked this one. It's the peice you see on the back door. It's off. That moulding strip/trim peice/ blah blah. I dont know what you call it.. any help would be appreciated.
Old Jul 20, 2006 | 05:26 AM
KillerElfboy's Avatar
Default Re: cheap fix for my trim peice? (wcsh86)
Ah, i believe this is called weatherstripping, theres some slang tho for it too. You can find a piece like this on Ebay, altho i dont konw if you'll find a painted one, but yes you could paint it yourself.
Old Jul 20, 2006 | 05:30 AM
kniob's Avatar
Default Re: cheap fix for my trim peice? (KillerElfboy)
pretty sure this is it:
http://www.hondaautomotivepart...ERIOR
115951 TRIM, L. RR. NO COLOR 24.70 18.52
$18.52.
EDIT:
I might have lied, it's probably this:
http://www.hondaautomotivepart...PANEL
117180 018 1 WEATHERSTRIP, L. RR. NO COLOR 41.39 31.04
Modified by kniob at 10:06 AM 7/20/2006
Old Jul 20, 2006 | 06:45 AM
wcsh86's Avatar
Default Re: cheap fix for my trim peice? (kniob)
http://cgi.ebay.com/ebaymotors...ZWDVW
This is actually the peice i'm looking for. But..
I dont have the clips to put it on, and is it feasible to actually match 12 year old paint?
Old Jul 20, 2006 | 02:38 PM
well, you could go to a shop, give them the code and maybe they could mix you up some
Old Jul 20, 2006 | 04:40 PM
wcsh86's Avatar
is it not going to be different bc it's 12 years old?
Old Jul 20, 2006 | 09:29 PM
SuShiBoiiii's Avatar
well if it was properly cared for it shouldnt be to bad but if its had a lot of wear and tear just see if they can blend it where they paint around the molding to sorta make it match
Old Jul 20, 2006 | 09:59 PM
Default Re: cheap fix for my trim peice? (SuShiBoiiii)
i think after a couple weeks in the sun it will pretty much blend to the rest of hte car
Old Jul 21, 2006 | 02:45 PM
EASY101's Avatar
* B A N N E D *
i used to work in paint & auto body....the paint still will not match perfectly but will be close enough and who cares anyway, its a small part (molding) Its not like its an entire body panel. Besides that, the difference in color wont be off by that much and it will still look a lot better than it would with the molding missing.
Old Jul 21, 2006 | 02:49 PM
Intense3.2's Avatar
Default Re: cheap fix for my trim peice? (EASY101)
Cant really see it as it is anyways... your good with a black car.
Old Jul 21, 2006 | 03:05 PM
EASY101's Avatar
* B A N N E D *
Default Re: cheap fix for my trim peice? (Intense2.2)
that black car isnt his, if you read his post...he was only using the picture as an example.
Old Jul 27, 2006 | 01:08 PM
wcsh86's Avatar
anyone know where I can get the clips for the part?
Old Jul 27, 2006 | 01:27 PM
EASY101's Avatar
* B A N N E D *
majestichonda.com or your local dealer or a junkyard
Old Jul 27, 2006 | 03:10 PM
YeuEmMaiMai's Avatar
hondaautomotiveparts.com (majestic)
Old Jul 27, 2006 | 03:18 PM
wcsh86's Avatar
Default Re: (YeuEmMaiMai)
preciate it..
jkm211
Paint and Body
Dec 13, 2010 07:55 PM
EF_9
Oct 28, 2008 05:21 PM
furyskater16
Mar 22, 2008 12:06 PM
EMod Civic
Welding / Fabrication
Dec 2, 2005 04:02 PM
wetzelman1
Jul 12, 2004 07:04 PM
