Looking for ways to smooth out a bumpy ride
Old Apr 21, 2002 | 10:28 PM
Rincon's Avatar
Default Looking for ways to smooth out a bumpy ride
I have a very bumpy ride thus far with my 1988 crx-dx and need some help figuring out how to smooth out how my car rides.
My car is currently lowered about 1 1/2 inches from the stock height.
I am currently running on 205-40-16 kumho tires with Skunk 2 coilovers (400 spring rate on the front/300 spring rate on the back), with stock struts.
I am changing my stock struts to Koni Yellows this week, but I am wondering if there is something else that would also be contributing to the bumpy ride I have.
I am experiencing rebound but I also hit the bottom (roughing up the bottom of my header a bit) more so than I should.
Any suggestions that you all have would be great.
Old Apr 21, 2002 | 11:42 PM
SIRX's Avatar
Default Re: Looking for ways to smooth out a bumpy ride (Rincon)
Just an idea but what pressure are your tires running at? Usually dropping a few psi will smooth out the ride alot. The reason this works is: Let's say your running a 205/45-16,and the max tire pressure is 35psi and it will support a load of 900 pounds. Well you take 900*4=3,600 pounds. Now if your car only weights 2,000 pounds your tires don't need to be at max. pressure. Lowering the pressure will make it ride better. In my 67 Camaro (The rides fine in the crx) I run 28psi in the front and 18psi in the rear and it rides great. Experiment(sp) with pressure until it rides better. It is also good to use a pyrometer to check the temp across the tread pattern. Try to keep the temp. the same all the way across. Look on your side wall and find your max pressure and drop it accordingly from there. Also, changing tire pressure will affect your launching and cornering. I would keep a log of what different pressure does to the car. goodluck
[Modified by SIRX, 8:44 AM 4/22/2002]
Old Apr 22, 2002 | 05:27 AM
Jesse H's Avatar
Were you expecting a properly dampened and compliant ride with 400/300 spring rates and a slight drop in ride height on original shocks?
Old Apr 22, 2002 | 06:47 AM
SCsol's Avatar
Default Re: (Jesse H)
DO NOT REMOVE tire pressure Rembber the ford EXplodeders. keep the tires at what is says on the side wall it there for a reason. if you want a smoother ride get ride of the coil overs and get a set of progressive springs with a good shock thats adjustable !
Old Apr 22, 2002 | 07:39 AM
MaddMatt's Avatar
Default Re: (lowsol)
Your answer is in this sentence:
Whydid
May 18, 2015 03:26 PM
maximusmda
Suspension & Brakes
12
Sep 16, 2009 01:08 PM
Ultraspeed DC2
Sep 21, 2008 10:19 AM
yanman
Suspension & Brakes
Jun 5, 2006 02:45 PM
raziel13
Suspension & Brakes
22
Mar 1, 2006 11:12 AM
