Help dont know what happened
So i was driving down the highway and all of the sudden my steering wheel got really tight and started pulling to the left then it started shaking really hard so i pulled the car over. when i tried to put it in gear and drive again the car wont move. car starts fine and engine seems to be running fine but wont drive. no ecu codes. car is an 88 crx with a jdm b16 and y1 tranny
no tranny fluid leaking and car is level. i was thinking it could be an axle. but was coming home from a long road trip and needed to go to work so i didnt look. just got the car towed.
im thinking .. either sumthing to do with the brakes or a bearing. sumthing thats keeping ur car from going anywhere. could also be a seized tranny. i was once driving an 87 accord when similar symptoms like urs occured. it turned out i had aloose tranny drainage bolt thus loosing all my tranny fluid, eventualy F'ing my tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx »</TD></TR><TR><TD CLASS="quote">how hard is that too fix and where can i find the parts for my setup</TD></TR></TABLE>
If you have never done it, I suggest you not attempt it yourself. Make sure to check your tie rods too.
wwang924
Nov 1, 2005 03:35 PM
