Which NGK Plug part number for TURBO 6th Gen 1999 Accord?!?!?
Old Jul 19, 2006 | 09:35 PM
ykwak's Avatar
Default Which NGK Plug part number for TURBO 6th Gen 1999 Accord?!?!?
Hello guys,
i am wandering which NGK plugs are ideal for a 6th gen f23a1 4cyl boost setup. Running 7psi on stock bottom end.
Anyone know the NGK partnumber that is good for this application?
i need a gap of .030.
Old Jul 20, 2006 | 04:25 AM
khunt0012's Avatar
Meat Robot Invisible
Default Re: Which NGK Plug part number for TURBO 6th Gen 1999 Accord?!?!? (ykwak)
http://www.ngk.com - That was hard. I'm not doing all the work for you though.
Get something like a copper plug which runs colder.
Old Jul 20, 2006 | 05:39 AM
notoriousB's Avatar
use ZFR7F-11 (2 steps colder than stock)
you will need to gap it down yourself.
Old Jul 20, 2006 | 06:03 AM
v4lu3s's Avatar
RTFM
BKR7E is a better choice if you ask me. Same heat range as the zfr7f-11 but the tip does not extend as far out, meaning that it transfers heat to the head a lot faster, meaning its less prone to detonation than just a cooler plug.
jyracer
Dec 7, 2008 07:16 AM
pos_cd5
Aug 26, 2006 10:48 AM
SiEcO187
Jul 5, 2005 09:37 PM
Hoodwinked
Oct 24, 2003 08:45 AM
ELUD THS
Aug 21, 2002 08:35 PM
