K20a3 EF
Old Jul 19, 2006 | 09:06 PM
project ak's Avatar
Default K20a3 EF
I have an 89 CRX DX, and was wonder if it would be smart to swap to a k20a3 USDM Type s?
I'm asking because a friend told me that all that power might not hit the ground, and peel out all day.
Old Jul 19, 2006 | 09:09 PM
CRXBart's Avatar
Default Re: K20a3 EF (project ak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project ak &raquo;</TD></TR><TR><TD CLASS="quote">I have an 89 CRX DX, and was wonder if it would be smart to swap to a k20a3 USDM Type s?
I'm asking because a friend told me that all that power might not hit the ground, and peel out all day.</TD></TR></TABLE>
A type-s is a k20a2. the a3 is the RSX base. Buy some Azenies it will hook good. Also buy an LSD.
Old Jul 19, 2006 | 09:12 PM
EF_ST@TUS's Avatar
question answered!!
bart knows his shiz...
Old Jul 19, 2006 | 09:21 PM
Smokinsax's Avatar
The Boot
its a front wheel drive honda...you cant get traction with a d15.
Old Jul 19, 2006 | 09:40 PM
doublethink's Avatar
Default Re: (Smokinsax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax &raquo;</TD></TR><TR><TD CLASS="quote">its a front wheel drive honda...you cant get traction with a d15. </TD></TR></TABLE>
haha. with an HF you can, even if you dump it.
believe me i've tried.
Old Jul 19, 2006 | 10:49 PM
Rywire's Avatar
Default Re: (doublethink)
Dont waste your time on a k20a3! Buy a b16a, save some time/money
Old Jul 19, 2006 | 11:25 PM
Smokinsax's Avatar
The Boot
Default Re: (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Dont waste your time on a k20a3! Buy a b16a, save some time/money</TD></TR></TABLE>look who's talking!
Old Jul 19, 2006 | 11:30 PM
Rywire's Avatar
Well, think of it this way... It makes 160whp(same as b16a)... It costs the same as a b16a (for the engine), but the parts to put it in are just as expensive as the 220 hp k20a.
Old Jul 20, 2006 | 01:57 AM
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Well, think of it this way... It makes 160whp(same as b16a)... It costs the same as a b16a (for the engine), but the parts to put it in are just as expensive as the 220 hp k20a. </TD></TR></TABLE>
160 crank hp. ****, he's lucky if it puts out 135 to the wheels.
you do have a really good point though.
Old Jul 20, 2006 | 03:55 AM
charlee's Avatar
if he wants to go somewhat original... he can always drop in a K. thats IMO
Old Jul 20, 2006 | 05:06 AM
CRXBart's Avatar
Default Re: (charlee)
The quote in my sig is in reference to doing a K swap other than a K20A swap. Unless you are doing atleast an A2, then it isn't worth it.
Old Jul 20, 2006 | 05:40 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Kick your friend right square in the nut sack.
Old Jul 20, 2006 | 09:00 AM
Default Re: (SloS13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloS13 &raquo;</TD></TR><TR><TD CLASS="quote">Number of threads about K's in an EF: 18,228,109
Number of K's in an EF: a handfull</TD></TR></TABLE>
baaaaaaaaaaaahahahahahahaha
Old Jul 20, 2006 | 09:05 AM
CRXBart's Avatar
Dammit am I gonna have to go back out in to the shop and put my motor back in?
Old Jul 20, 2006 | 09:32 AM
Ass$nyper's Avatar
Pirate General...YARRRR
I'll agree and disagree.
It's so cheap now and even though its only 160 hp look at the ft lbs and powerband plus how easy once its all done you can upgrade.
But if you are doing all that work yes I see the point of doing it right the first time.
Just wanted to point out the other veiw on it. If I went K i'd probbly use an a3 honestly.
Old Jul 20, 2006 | 10:16 AM
xDicktonesx's Avatar
Default Re: (***-assin)
the a3 is a waste of time. too much fab work for a motor that has virtually NO aftermarket support and will make less power than a gsr (which can nevar loooose)
and im pretty sure the a3 has a 5 speed tranny. it does make more power "under the curve" &lt;--something few people here fully understand, but a gsr with bolt ons is a better horsepower perdollar value than a k20a3.
Old Jul 20, 2006 | 05:55 PM
EF'n Stig's Avatar
Default Re: (xDEFTONESx)
i'd be cheaper and more toque to get a k24, they are a dime a dozen comming out of rolled elements and totaled accords rather then importing them, and if u swap a k20 head u can get alot more power out of them they ended up with 275 hp with the stock bottom end
http://www.sportcompactcarweb.....html
Old Jul 20, 2006 | 06:06 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xDEFTONESx &raquo;</TD></TR><TR><TD CLASS="quote">the a3 is a waste of time. too much fab work for a motor that has virtually NO aftermarket support and will make less power than a gsr (which can nevar loooose)
and im pretty sure the a3 has a 5 speed tranny. it does make more power "under the curve" &lt;--something few people here fully understand, but a gsr with bolt ons is a better horsepower perdollar value than a k20a3. </TD></TR></TABLE>
Didn't know that Thanks Chad
I am no means a K expert and I thought most the aftermarket was interchangble, guess not. Yea they are 5spds too.
whiteguyndahood
Nov 8, 2006 02:40 PM
coldtotouch
24
Sep 14, 2005 06:27 AM
2kTeg
Apr 7, 2005 05:18 PM
b20turbojason
Jun 30, 2004 11:20 AM
patastinky
Feb 18, 2004 10:10 AM
