rear disk swap into 90 hatch....are crx rear disks just as good as DA?
Gonna try to score some trailing arms/rear disks for my hatch tommorrow at the junkyards
There are more CRX's than tegs in the yards around me, if i can find a CRX with rear disks is that setup just as good/swappable as DA parts?
I know the ebrake setup is a little different, what all parts would i need to grab, just the cables?
Yes, they are the same except for the length of the e-brake cables. The 90-91 CRX Si e-brake cables are of course a perfect fit for yours.
jesus, just called advanced auto and napa, rebuilt calipers are 82 each plus core, thats a lot more than i was expecting...that makes this quite an expensive swap, till you get done buying the trailing arms from a junkyard, picking up new calipers/rotors/disks...possibly brake lines
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drew2 »</TD></TR><TR><TD CLASS="quote">what does a set of loaded trailing arms go for?
Loaded trailing arms? I have never heard of the term. Why don't you just buy the complete rear disc swap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drew2 »</TD></TR><TR><TD CLASS="quote">....same thing
that is what im trying to buy</TD></TR></TABLE>I paid 125$ back in 04' for my DA rear Arms complete with everything attached.
Ahhh, you mean a complete set of rear disc brakes? Well that all depends on the place you buy them at, but usually within the $150-$200 range.
yard near me wants $250...bastards
another quick question to tag in here...are 90 Si front brakes and EX front brakes the same?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drew2 »</TD></TR><TR><TD CLASS="quote">yard near me wants $250...bastards
At that price, are they going to take them off?
No, the Si brakes are smaller. You want the EX brakes since they are bigger.
alright, what all do you need from the EX
caliper, rotor and the upright (called the knuckle?)
and im assuming these fit under 14inch steelies as thats what ex's came with right
i'm not sure if they fit under 14's I have 15".
You need Comlete knuckle and hub assem. from an EX/DA minus UCA .
Use LCA from your car
Axels?
I have 90 teg but they are blown now.... I think I need Del Sol's I dont know, I need help too!!
Axels?
hmotors has the whole rear disc swap for 200 w/e-brake cables
I used DA trailing arms but it threw off my camber and i don't have e brake right now so i wanna get the ef rear disc
i got mine at Ecology during their 50% off sale, it cost a little over $40 dollars which means regular price is in the neighborhood of $80-$90. if possible, try to find out when the next sale is if you have an Ecology junkyard near you. $40 is an awesome price!!! it included both trailing arm, rotors, calipers, and e-brake cables.
jesus...got quoted $250 and $300 from the two junkyards around here that had any (out of the 20 i called)
went to U-pull it place and found a teg w/ the rear brake setup intact.
unfortunately it wsa super rusty and i couldnt get 3 of the bolts off
left the yard with it half taken apart when it closed...not sure if its worth my time driving back to get the parts....seems like w/ that much rust i could have problems w/ the calipers/bleed valves
silver_flash99
Oct 19, 2005 11:37 AM
